Sharp Aquos lc-70le857u 70" TV display problem
  • egreene15
    • Nov 2015
    • 16
    Hey everone, i'm new here and have spent a few days searching threads for my symptoms but haven't found anything...I'll quickly describe and see if any of you can help.
    My in-laws tv stopped working a few months ago, threw the 2-5 blinking code and wouldn't turn on. Being out of warranty, barely, and not wanting to spend more money on it (was already replaced one), they put it aside, unplugged. Fast forward a few months to earlier this week...I plugged it in and there was no error code! However the display was clearly not working correctly, no A/V sources are connected to the tv, on power up i never saw the SHARP logo screen or anything for that matter, i hit the menu button on the remote and could see the menu titles but they weren't normal colors and they appeared on the screen slowly (took about 30 seconds for the image to get full bright) If i tried to scroll it would again take 30 seconds for the screen to show any response.
    I have talked to SHARP and done a hard reset, they said i would have to have it "serviced". Picture below is what it currently looks like when i turn it on, the longer i leave it on the brighter the image gets, all the way to the point where the entire screen is bright yellow/white. I have checked and get 12vdc to the Tcon board, no physical damage to the screen either.
    When i go into the service menu during the hard reset i get almost a perfect picture and brightness...
    Send me any thoughts!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sharp Aquos lc-70le857u 70" TV display problem
    Sounds like Mainboard failure to me.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Try possibly heating the Mainboard with hair drier to see if it clears up the issue.
      • budwich
        • Jul 2015
        • 3097
        its appears to be the "standard" bad tab issue. You can search thru here using either "sharp 70" or "vizio 70"... there are lots of threads in and around this problem. The set can't be fixed because the tabs are not replaceable BUT it can be "saved" by removing the defective one (s) on one side or the other.... but you only get one chance to make a choice so proceed with care.
        this is my "story" https://www.badcaps.net/forum/showth...light=sharp+70
        • egreene15
          • Nov 2015
          • 16
          Originally posted by budwich
          its appears to be the "standard" bad tab issue. You can search thru here... there are lots of threads in and around this problem.
          Read a little about it I think when I was thumbing around here, if I remember correctly there is no easy solution of just replacing a board is there?
          • budwich
            • Jul 2015
            • 3097
            Yep.... lots of successful "saves" so it can be done. People will help so go slow, make sure you understand what's happening and where. By removing cables (unclampable one), you can eliminate which side is bad. That's the process.
            Of course, the task is somewhat difficult because of the size of the set, and the amount of space you need to work on it.... but slow and sure will get you there.
            • egreene15
              • Nov 2015
              • 16
              Tried that and no change...thanks for the idea!
              • budwich
                • Jul 2015
                • 3097
                • egreene15
                  • Nov 2015
                  • 16
                  Thanks! I went thru your thread earlier and don't think I have a bad side, no issues when connecting or disconnecting my tcon ribbons
                  • budwich
                    • Jul 2015
                    • 3097
                    actually you need to disconnect the "corner cables" to eliminate the possible "tab problem". In my case, the tab driver was causing enough issue for the code flash but there were time when it was OK so it depends on how "bad" the tab might be. Anyways, good luck in your "quest".
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      This looks like a bad tcon board. Especially since it appears that the screen is holding images. Like image retention. Mostly a problem with the gamma processor on the tcon. Locate the ic labeled Maxim. Are you getting a steady 2.2v to it? This board would also hold the responsibility of originally throwing the 2-5 error.
                      • egreene15
                        • Nov 2015
                        • 16
                        I took off the tcon board and looked on both sides for an IC labeled Maxim but couldn't find anything. Here is a picture if that helps you guide me...
                        I've been thinking its a tcon issue all along but not sure how to test it...thinking about just ordering a new board and testing it by pure replacement. Happy Thanksgiving everyone!
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          I'm thinking of.IC6801
                          • egreene15
                            • Nov 2015
                            • 16
                            Thanks for the help freakaftr8! Any good references on how to check voltage on an IC?
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              On those im not too sure. But the voltages on a normal as15 should range from 0 to 12v on each pin incrementally increasing on each pin.
                              • egreene15
                                • Nov 2015
                                • 16
                                Well I swapped out the T-Con board to no avail, still same issues. I've got a power supply board on the way and I'm going to try that. I did a hard reset after I swapped the tcon board, does anyone know if I need to do anything else after swapping a board that could maybe reset things? Thanks for your help!
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  I think you have nothing to lose by disconnecting the corner interconnecting cables (one on each side, one at a time) and see if it changes anything.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Wow im surprised ghe tcon didnt fix it. Power supply is most likely ok. Id say panel issue now. Try disconnecting one side at a time on the panel to tcon and see if picture stays the same on either side.
                                    • egreene15
                                      • Nov 2015
                                      • 16
                                      So power supply board is ok, swapped it out and no change as predicted. I unhooked the right corner(looking at the back) interconnecting cable and the opposite side screen(right side, looking at the screen side) looks perfect. I unhooked both back corner cables and got a bright white screen with flickering lines all over. I unhooked just the back left cable and screen pretty much stayed the same as if i hadn't unhooked anything. Thoughts?
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        You are there... :-) Not sure about your "right and lefts"... but it doesn't matter. The side that you connected back up and got nothing (same of all unhooked), that's the side that is BAD..... because the set was trying to work running with that BAD connection and it obviously can't. So go slow still. Go back to the "good screen mode" and take a picture and post (use some good video input from a test dvd or something people will know exactly what you are seeing will help significantly). Without this, you may be still looking at multiple tab problems... only a good picture of a good test screen will help confirm things.
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • Yehuda170
                                          ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                          by Yehuda170
                                          original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                          replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                          now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                          with original broken screen i can see in device manager touch screen in human interfaces
                                          but with the new screen it's not showing in device manager
                                          is it lenovo blocking it? is it driver missing?
                                          I²C is a headache
                                          07-14-2023, 01:29 AM
                                        • thesharpfella
                                          Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                          by thesharpfella
                                          Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                          07-23-2024, 10:37 AM
                                        • EazyBone
                                          Sharp LC-65Q620U White Screen
                                          by EazyBone
                                          Another TV topic!!
                                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                          08-21-2024, 12:56 PM
