Panasonic TX-P42C2l : No Power with 4 LED Blinks
  • bigbadtom
    • Oct 2014
    • 11
    • Ireland
    hi i have this issue with panasonic tv.
    read in other post about disconnecting the sc and ss board and SOS light should change but didn't change
    looked for obvious problem like caps on all board but cant see anything that is obviously shorted
    anybody any advice for me
    mechanical engineer slight electronic experience but not enough
    thanks guys
    Re: Panasonic TX-P42C2l : No Power with 4 LED Blinks
    Could you perhaps supply pictures of the parts inside the TV, and one of the whole TV with the cover off? So we can see what we are dealing with.
    • bigbadtom
      • Oct 2014
      • 11
      • Ireland
      Please see attached any help gratefully accepted
        Ok, so in the condition there you still have the SS connected to the P board. Have you tried disconnecting that and powering the TV up again?
        • bigbadtom
          • Oct 2014
          • 11
          • Ireland
          disconnected the ss board. and sc board at same time light changed to six blinks
          reconnected the sc board without ss connected and went to seven
            Ok, can you try the set with the SC and SS connected again and verify you are back to 4 blinks. And when you have the SS disconnected could you check that it is definitely 7 blinks you see and not 8.
            • bigbadtom
              • Oct 2014
              • 11
              • Ireland
              Both boards connected it's 4
              yes with ss board ( the one to top right in pic) disconnected and the sc connected it's 7
                Ok, my guess would be the SS board is shorted. Can you remove the board and get clear photos of the top and bottom of the board? Do you have a digital multimeter available?
                • bigbadtom
                  • Oct 2014
                  • 11
                  • Ireland
                  removed board hope you can see I found issue all eight same component have blown one of its legs.
                  solution is to buy second board?
                  but what caused it may cause it again?
                  • tw2005
                    • Oct 2011
                    • 6458
                    If you can't find a board, I've had success repairing these by replacing the 4 RJP30E4 transistors. The M817135FP FET driver seems to survive although not a bad idea to replace it.
                    easiest way to remove the transistors is either snip the legs close to the body without twising them or the track will tear or heat the solder and lift each leg whilst the solder is molten. Then you tin the meatl tab and heat until it bubbles and get the body off. I get away with a 40w iron and medium tip.
                    I did have one board I used fail again after a few days. Not sure why, I got the parts from china so maybe that but my second bpoard I had a 50" board I stripped the transistors from that and that has been fine, also I replaced the FET driver. The first one I did not, again possibility.
                    Glad I asked what model you had, kind of makes a big difference with the answers you get.
                    The SS failure in these is very common but it can also take out the SN board, hopefully you had SS3 disconnected when you powered up isolating the SS.
                    May pay to bell out the large transistors on the SN too. There's a couple of SMD diodes that can blow too, D441,452.
                    • tw2005
                      • Oct 2011
                      • 6458
                      Make sure you get the correct revision board or else it won't connect to the ribbons. There is an alternate fitted to some US Sanyos with the same panel. these are starting to get scarce and more expensive
                      • bigbadtom
                        • Oct 2014
                        • 11
                        • Ireland
                        Think I have one for 75 euro not too bad. hope it doesn't blow. as regard to getting the sos three didn't happen at0any stage.
                        wonder why not.
                        not very electronically experienced so think will take hit on board and hope for best
                        you agree?
                        • tw2005
                          • Oct 2011
                          • 6458
                          wonder why not.
                          you agree?
                          No, SS3 = connector SS3 on SS that connects to SN3 (SN board)
                          Ouch. What does 75 euro translate to GBP? That would be $110 AUD for me
                          You might get some change back for the old board selling it. Somebody may like to repair it. cheap repair parts wise.
                            When you say blown off the leg... you're not talking about the stub leg right? That is normal for those devices.
                            You should check if they are shorted with a multimeter.
                            • tw2005
                              • Oct 2011
                              • 6458
                              I'd still be checking out the SN as a precaution. I have read a post where a new board got killed by another and they went around in circles for a bit. Would have to do a search. Going back a bit now.
                              • tw2005
                                • Oct 2011
                                • 6458
                                It was this one I think. https://www.badcaps.net/forum/showth...npa5072&page=2
                                the way I read it , SOS 4 cleared with new SS, (no SN) after everything hooked up he ended up with another fault, then somehow ended up with shorted SS again so I'm presuming his SN was damaged also and killed the SS again.
                                Just something to be aware of as there is an assumption the SN is still good at this point.
                                • bigbadtom
                                  • Oct 2014
                                  • 11
                                  • Ireland
                                  Have to leave it for tonight unfortunately.
                                  tw2005 you mind if I give you private messagage tomorrow?
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    If you feel it's necessary, nothing wrong with keeping it posted here.
                                    I'm just jumping in because I have the same Tv and also some spare working boards to check stuff + I've made some mistakes and popped the Sn twice now fault finding it.
                                    • bigbadtom
                                      • Oct 2014
                                      • 11
                                      • Ireland
                                      Not sure if my multimeter read transitors maybe just solder legs and cross fingers
                                        You can check for shorted transistors with the diode or 200 ohm range of your multimeter. Just check across all pin combinations of the transistor.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
