Repairing 'display on for 3-5 seconds, then no backlight' displays (all makes)
  • Curt Palme
    • Jul 2010
    • 7
    I'm not sure if this has been covered here, but I figured this post might help someone....
    As a sideline to my CRT projector repairs, I have gotten into refurbing LCD computer monitors, from 15" to 22". I have a deal going with a couple of local computer stores that I get all of their bad trade in monitors... So I've been through about 200 now, and the vast majority of problems, dead monitors, intermittent backlight etc, are indeed due to bad capacitors. That topic is covered here to death, so I won't touch it.
    About 50 monitors that I've been stockpiling here though have the 'the monitor works for about 3-5 seconds, then the backlight shuts off' problem. I scope and replace capacitors in the power supply, the whole power supply is stable, yet the backlight still doesn't work.
    So,, on Friday I finally decided to attack these monitors, since I now have duplicates of many models, so I put a defective one beside a working one to compare the two.
    As someone had written on another post here, the backlight driver design is pretty slick:
    -If it detects a short/overload, it shuts down.
    -if it detects an open circuit, it shuts down.
    With a typical monitor, there are two backlights, one at the top and one at the bottom of the screen. These mini fluorescent tubes shine into a piece of plexiglass that's etched to refract the light towards the LCD screen.
    Playing around with the working monitor, I found that disconnecting one of the backlights, would shut down, as one driver has an open circuit.
    I then carefully pulled apart the working monitor and removed one of the working tubes and wiring assembly. This is finicky work, as you have to be really careful not to stress the very thin PC board ribbon cables going between the LCD panel and the LCD driver PC board.
    Once I opened the LCD panel that was shutting down, I found the problem: One of the backlight tubes was broken, and once apart, I could smell the ozone created by the arcing HV, as the break was close to one end of the tube, and it appeared that the HV was arcing to the chassis/ground.
    It appears that the length of the fluorescent tube is not important. It was a 19" widescreen panel that I pulled apart to get my 'test' light tube. I have since used it as a test light for other 15" to 22" panels, and very quickly I can determine whether the top or bottom tube is defective by simply disconnecting each internal light and connecting my known working tube to it.
    In one case I've found Hv arcing from the wiring to the chassis/ground, but in most cases so far the light tube itself is either defective or broken.
    Only 45 more monitors to go through....
  • alexanna
    • Mar 2010
    • 1346
    Re: Repairing 'display on for 3-5 seconds, then no backlight' displays (all makes)
    I do the same thing you do as far as using known good ccfl tubes to rule out bad ccfl tubes.
    I ran into one that just might bite you in the butt, it was an Acer AL1714 The ccfl tubes are horse shoe type. My problem turned out to be a voltage supply problem, But these ccfl tubs are a whole lot longer.
    It is just something to be aware of.
    Al.
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
    • twonk9098
      Lenovo Legion 5 high fan spin turns off after 34 seconds
      by twonk9098
      I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
      I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
      I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
      I have tried a few new bios but exactly...
      07-14-2024, 11:19 AM
    • liquidzorch
      Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
      by liquidzorch
      Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
      10-18-2024, 05:19 PM
    • Rick_1234
      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
      by Rick_1234
      Good evening, gentlemen.
      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
      https://drive.google.com/file/d/1L6S...ew?usp=sharing
      Things I tried
      - Bought a new AC adapter thinking that was the problem but the problem...
      06-22-2024, 04:44 PM
    • PowellSkier
      Harman/Kardon AVR 645 returning to stand-by after a few seconds.
      by PowellSkier
      A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
      06-17-2024, 11:43 AM
