bios for lenovo ip 3 15IIL05 GS454/GS554/GV450/GV550 NM-D031
  • chadiii
    • Jan 2020
    • 2
    • beirut
    hi .... can any body help me ... i need bios for lenovo ip 3 15IIL05
    OR GS454/GS554/GV450/GV550 NM-D031 REV:1.0
  • peste
    • Dec 2016
    • 13661
    • ROMANIA
    Re: bios for lenovo ip 3 15IIL05 OR GS454/GS554/GV450/GV550 NM-D031
    post the backup of the original bios
    • lazybigyan
      • Mar 2017
      • 81
      • Nepal
      Here you go.
      • lorfe1
        • Jun 2021
        • 5
        • republica dominicana
        That is same than Ideapad 3 15ikb?
          • 22001
          No, its for these models - IdeaPad 3 14IIL05/IdeaPad 3 15IIL05/IdeaPad 3 17IIL05/Lenovo V17-IIL
          • bokeboke
            • Jul 2021
            • 30
            • Albania
            Hi friends i have dhe ideapad 3 bios dump but need to clear me
            please canu help me to get Clean me for my dump
            REGARDS
            • klean
              • Feb 2020
              • 37
              • Albania
              Need bios for lenovo ideapad 3 15iil05
              please help me with bios dump for lenovo ideapad 3 15iil05
              original file bios
              • lapfix
                • Mar 2020
                • 2765
                • my workshop
                Re: Need bios for lenovo ideapad 3 15iil05
                What's your Issue !!
                Post your serial number
                  • 22001
                  original file bios
                  Post the serial and model type,it saves us time .
                  • klean
                    • Feb 2020
                    • 37
                    • Albania
                    hey hello lcd stay black,, serial gs454/gs554/gv450/gv550 rev 1.0 nm-d031
                      • 22001
                      Post the serial number on the case,and model/machine type
                      • klean
                        • Feb 2020
                        • 37
                        • Albania
                        sn: PF2EPHLV IDEAPAD 3 15IIL05 MTM : 81WE00T2RM
                        • lapfix
                          • Mar 2020
                          • 2765
                          • my workshop
                          try
                          • klean
                            • Feb 2020
                            • 37
                            • Albania
                            Thnx i will try right now
                            • klean
                              • Feb 2020
                              • 37
                              • Albania
                              Originally posted by lapfix
                              try
                              still same bro
                              • klean
                                • Feb 2020
                                • 37
                                • Albania
                                try
                                hello bro , now when i plug the charger power led flashing and when i connect battery it dosent flash just stay solid
                                • lapfix
                                  • Mar 2020
                                  • 2765
                                  • my workshop
                                  still same bro
                                  try
                                  • pirusvlad
                                    • Apr 2021
                                    • 13
                                    • uk
                                    try
                                    Can you please try to unlock my bin file?
                                    • pirusvlad
                                      • Apr 2021
                                      • 13
                                      • uk
                                      Here it is
                                      • faysal
                                        • May 2015
                                        • 22
                                        • Pakistan
                                        kindly help me repair my bios also
                                        IDEAPAD 3 15IIL05
                                        S/N PF2EH86T
                                        ORIGINAL BIOS ATTACHED
                                        • vrem
                                          ideapad 3 15iil05 gs454/gs 554/gv 450/gv 550 nm-d031 disable onboard ram
                                          by vrem
                                          i have ideapad 3 15iil05 board gs454/gs 554/gv 450/gv 550 nm-d031,
                                          someone can help me to disable onboard ram?
                                          is possible just swap resistor?
                                          here board pic
                                          thank in advance for any help...
                                          01-16-2022, 04:51 PM
                                        • yaso143
                                          lenovo ideapad 3 14il05
                                          by yaso143
                                          gs454/gs554/gv450/gv550 nm-d031
                                          can anyone help ?
                                          first issue short in main power rail fixed by replacing a mosfet
                                          new issue
                                          unit turns on after 5 seconds it turns off (when battery is plugged)
                                          unit turns on then off immediately(when batt is unplugged and using charger only)
                                          main power rails are present 20v , 3.3v is present 5v is present 1.8v is present when unit is turned on 1.8v shows then disappear when unit shuts itself down
                                          also i noticed that cpu is getting hot then turns off do you have...
                                          08-03-2023, 10:12 AM
                                        • kalilinux25
                                          Lenovo IDEAPAD 3 14IIIL05 no display keeps restarting
                                          by kalilinux25
                                          LAPTOP: IDEAPAD 3 14IIIL05
                                          MODEL NAME: 81WD
                                          SERIAL NUMBER: PF2K713H
                                          BAORD: GS454/GS554/GV450/GV550 REV 1.0 NM-D031 2019-12-06
                                          PROCESSOR: i3-1005G1
                                          GRAPHICS: NO GFX
                                          ONBOARD RAM
                                          ISSUE: NO DISPLAY
                                          taking 30milliamp
                                          ALW_PWRGD-3.1v on and off state
                                          EC_RSMRST#- 3.0v
                                          PCH_PWROK- 0v onstate and off state 9.9k ohms
                                          PM_SLP_S3#- onstate 0v off state 0v
                                          PCH_DPWROK-3.0v on state and off state
                                          VCCST_PWRGD_R- 0v on/off state
                                          +VCCIN_AUX -0.8v
                                          +VCCIN- 0v
                                          +1.8VALW_P- 1.5v...
                                          04-11-2023, 01:19 AM
                                        • DiamondTech61
                                          BIOS for lenovo ideapad 3 NM-D031
                                          by DiamondTech61
                                          lenovo ideapad 3
                                          laptop board info-
                                          NM-D031
                                          Rev:1.0
                                          2019-12-06
                                          please can I have a bios.bin to flash as a last hope to revive?
                                          08-19-2022, 03:12 PM
                                        • Ardent1
                                          Lenovo IdeaPad 3 15IIL05 81WE New Blank Chip - help needed
                                          by Ardent1
                                          Hello everyone, I have never flashed a bios before and currently find myself needing to flash a new Winbond W25Q128JVSQ chip without the original bios file.. I have a CH341A programmer and have been able to connect the chip to neo-programmer, but that's about as far as my knowledge takes me so far. When i read the chip the data appeared to be all FF for every entry.
                                          I do not know the history of the motherboard, only that the old chip was removed because it was dead apparently. When the on button is pressed, the laptop on battery alone just shows a solid white light on the side and same on...
                                          12-18-2024, 02:52 PM
