Asus n751jk i need bios dump
  • okbalord
    • Jun 2017
    • 204
    • Algeria
    Need bios asus n751j
    thank you
    OKBALORD
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Asus n751j -help- i need bios dump-ty-
    thank you
    N750jk or jx ?
    • okbalord
      • Jun 2017
      • 204
      • Algeria
      hi ; sorry
      model N751JK -T7246H
      THANK YOU
      OKBALORD
      • cacla
        • Apr 2015
        • 442
        here it is
        • okbalord
          • Jun 2017
          • 204
          • Algeria
          thank you;
          the problème still present
          this laptop dont turn on , just a light on the key of power on the keyboard and i cant turn it on or off - frozen-
          the voltage : 3v present and 5v present eany help .???
          OKBALORD
          • cacla
            • Apr 2015
            • 442
            give me sn from your unit
            • okbalord
              • Jun 2017
              • 204
              • Algeria
              ok
              cn: 0434
              n751jk-t7246h
              thx
              OKBALORD
              • cacla
                • Apr 2015
                • 442
                this is not valid serial pls chek it again
                • okbalord
                  • Jun 2017
                  • 204
                  • Algeria
                  ok
                  OKBALORD
                  • cacla
                    • Apr 2015
                    • 442
                    Sorry for a late replay i joust see msg here it is your dump
                    • okbalord
                      • Jun 2017
                      • 204
                      • Algeria
                      np bro thank u
                      OKBALORD
                      • kkara567
                        • Jul 2021
                        • 3
                        Hello. Can I please get a bios dump for N751JX.
                        • peste
                          • Dec 2016
                          • 12652
                          • ROMANIA
                          post the backup copy of the original bios and clear pictures with the white / green stickers on the motherboard.
                          • kkara567
                            • Jul 2021
                            • 3
                            The pictures indicate all the available information on the board and housing. There are no other stickers or additional information on the board or housing.
                            • peste
                              • Dec 2016
                              • 12652
                              • ROMANIA
                              the pictures indicate all the available information on the board and housing. There are no other stickers or additional information on the board or housing.
                              try..
                              • kkara567
                                • Jul 2021
                                • 3
                                Thanks. I'll try and let you know how it goes.
                                • w2k6
                                  • Jan 2015
                                  • 16
                                  • romania
                                  N751JK rev. 2.0 BIOS
                                  Can anyone help me , please ?
                                  N751JK-T7085P
                                  G4N0CX12D67417D
                                  Thanks !
                                  • ahkh_72
                                    • Dec 2014
                                    • 103
                                    • Iran
                                    Re: N751JK rev. 2.0 BIOS
                                    Try This.
                                    .Today should be different from yesterday.
                                    • razor_amd
                                      [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                      by razor_amd
                                      With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                      For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                      I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                      This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                      12-15-2020, 07:07 PM
                                    • DynaxSC
                                      Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
                                      by DynaxSC
                                      I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
                                      The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
                                      Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
                                      Usually on ASUS boards it worked...
                                      06-14-2024, 03:49 PM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • Habble7
                                      I need a BIOS dump for the Samsung S49CG934SU monitor
                                      by Habble7
                                      The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                      Suspected Cause:
                                      I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • Anchar777
                                      ASUS P1412CE need BIOS DUMP
                                      by Anchar777
                                      Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                                      06-26-2025, 03:39 AM
