Magnovox 32MF231D
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Magnovox 32MF231D
    Originally posted by broksonic
    Ok, New DMM purchased (see pic).
    I think these are sold at Home Depot in Canada.
    With the new DMM set at 200 ohm the F75 (fuse) showed a .07
    The 3 voltage regulators (refer to picture) are as follows..
    DMM set at 20V DC
    7T10 pin 3 (top one in picture) 12.03
    pin 2 - 5.01
    pin 1 - 0.00
    7B45 pin 1 (right side in picture) 5.15
    pin 2 - 3.30
    pin 3 - 0.00
    7U28 pin 1 (bottom one in picture) 4.12
    pin 2 - 3.26
    pin 3 - 2.60
    The readings above indicate your fuse and voltage regulators are good.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      On the power board, there are two connectors, 1088 and 1089.
      1089 is numbered 1 to 10. 1088 is numbered 1 to 12.
      All readings will be done with TV plugged in and power on. Do NOT touch any of the heatsinks or any part of the power board.
      1) Put your black probe on a the ground screw where the number "2" is. It will be left there the entire time.
      2) Put your multimeter on 20V DC.
      3) Take readings of all pins on both connectors. If a voltage reads "1" or "0L" on the left hand side of the screen, that indicates "out of range". For that pin, switch the multimeter to 200V DC. Take the reading and then switch back to 20V DC.
      4) Report all your findings and note if the voltage changes or is steady.
      • broksonic
        • Apr 2012
        • 25
        • usa
        Connector 1088 (no voltage changes)
        pin 1 -24.2
        pin 2 -24.2
        pin 3 -24.2
        pin 4 -24.2
        pin 5 -24.2
        pin 6 -3.20
        pin 7 -0.76
        pin 8 -0.00
        pin 9 -0.00
        pin 10 -0.00
        pin 11 -0.00
        pin 12 -0.00
        Connector 1089
        pin 1 -15.61-15.78
        pin 2 -15.61-15.71
        pin 3 -24.2
        pin 4 -3.20
        pin 5 -0.78
        pin 6 -0.00
        pin 7 -0.00
        pin 8 -0.00
        pin 9 -1.25
        pin 10 -0.00
        Had readings change when lights flashed.. (refer to post #1 and #16). Also noted when lights went out connector 1089 pin #1 voltage continued to climb up into the 18.00 range. I assumed when the lights went out power was cut off, but guess i was wrong there.
        • retiredcaps
          • Apr 2010
          • 9271
          Is there a legend or label on the backside of the power board that lists the voltages? Some of the reported voltages are common among TVs except the 15.xx on pins 1 and 2 on connector 1089. Now it could be correct, but I cannot find a service manual so I don't know what the voltages should be.
          • TechShui
            • Jun 2011
            • 148
            Hello RC, earlier in this thread, budm linked to another thread with the 37MF231D service manual.
            His post was #4
            Here the manual:
            AFAIK, the 32MF231D does not have a seperate manual, but they both have the same TPE1.0ULA chassis. And the power board (and probably the scalar) is exactly the same.
            I have 2 of these same power boards now. Model 3138 103 6162. Both of them have 16.3V at pins 1 and 2 of the 1089 connector. So the reading seems OK.
            Broksonic, maybe if you press a little more firmly, you will get a steady reading, instead of fluctuating 15.61~.78v
            I started a thread almost 2 weeks ago, because I had the exact same problem, but then my symptoms changed when the scalar board's green LEDs stopped lighting up at all... to make a long story short, Retired Caps helped me determine the power and main (scalar) boards were bad.
            In your case, it sounds as though it might be just the scalar board that has gone bad.
            • broksonic
              • Apr 2012
              • 25
              • usa
              #26
              Sorry didnt see anything on back of any of the boards that would list voltages.
              • broksonic
                • Apr 2012
                • 25
                • usa
                #27
                His post was #4
                Here the manual:
                The only flux i had was in pins #1 and #2. The .78v was just in pin #5.
                I did retest both sets (10pins and 12pins) and got almost identical readings (within .02).
                • TechShui
                  • Jun 2011
                  • 148
                  My point exactly. When I wrote 15.61~.78v I was referring to pins 1 and 2
                  Pin 5 is just a signal. It doesn't provide power for anything in particular.
                  Page 55 of the manual says 16v, so again I will assume that your power supply is good.
                  NOTE: The slight variation might be an indicator that it'll soon be time to replace capacitor 2074, it's a 25v 2200uf Elite (known as a problematic brand).
                  It's not a major concern since the variation is 0.17v, but if/when you order any parts for your scalar board you might as well get a Panasonic FR capacitor to replace 2074.
                  The mainboard (aka scalar) is where you should focus.
                  This post might be of some help: http://www.riddledtv.com/forums/magn...-down-t45.html
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #29
                    I have done a pic of the connectors from the pdf
                    • broksonic
                      • Apr 2012
                      • 25
                      • usa
                      #30
                      I wonder if it might have something to do with that 5001 inductor with all that staining around it? Is there a way for me to test that? Or should i just go board shopping?
                      • TechShui
                        • Jun 2011
                        • 148
                        I went back and looked at your photo. Looks like burnt flux to me. Nothing to worry about.
                        You can clean it off with an old toothbrush.
                        I'm more interested in testing the crystal ocillator IC (1H00).
                        I suppose an ocilloscope is required for that? My question is directed to everyone. I've never tried troubleshooting an LCD mainboard, it just seems futile with all the hundredss of tiny components to comb over...
                        • broksonic
                          • Apr 2012
                          • 25
                          • usa
                          #32
                          Dont think this will help me but you might have equipment for testing.
                          Found this web page. http://www.electronicrepairguide.com...t-crystal.html
                          It mentions...
                          Second method is to use frequency counter to check the frequency of the crystal oscillator. The measurement must be taken when the equipment power is ‘On'. Put the probe of the meter or frequency counter to the crystal pin and read the measurement. Make sure your frequency counter meter has the range that is higher than the crystal frequency you are checking.
                          If the crystal is 8 mhz then your meter should have the range to be able to check that frequency. Assuming the readout of the crystal is 2.5 mhz then you know that the crystal is not functioning well and need to be replace. Normal digital multimeter usually has a small range for checking frequency. However the digital meter (Greenlee brand) that I'm using is able to measure up to 24 mhz. You can read the specification of your meter manual and see how high is the range is.
                          • TechShui
                            • Jun 2011
                            • 148
                            broksonic, have you tried testing that plug while it's disconnected from the scaler board? Obviously, they should stay steady when it's by itself.
                            The scaler is turning off and on in a loop. The voltage drops when it does. Something in the circuit is causing that, but I can't make heads or tails of the service manual's scaler board sections. They seem to be divided into subsections detailing microprocessor pinouts, digital signals, etc
                            I can't find anything detailing power distribution or where the 16v goes once it enters the scaler board? Not even a diagram of the whole board.
                            • broksonic
                              • Apr 2012
                              • 25
                              • usa
                              #34
                              I cant even GET a download of the manual. Everytime i try i get some .cgi file only about 517 bytes long.
                              Will try the plug disconnected and see what i get.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Disable all adblocking software. Goto the site. Wait 60 seconds and the get manual button will appear after it does all its "stuff".
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  #36
                                  What browser are you using- doesnt like Opera - optimised for firefox
                                  • broksonic
                                    • Apr 2012
                                    • 25
                                    • usa
                                    #37
                                    Pins 1 & 2 were steady at 16.9
                                    pin 3 steady at 24.2
                                    pin 4 steady at 3.2
                                    rest were signal pins or 0.0 (as per other post)
                                    Oh and the flashing from the Master Backlight inverter board has changed again.
                                    Now when scaler board green light kicks out, the red light flashes twice, pauses, flashes twice, pauses then flashes once.
                                    • TechShui
                                      • Jun 2011
                                      • 148
                                      We're still back at square one.
                                      We have to troubleshoot the scaler board at the component level, or shell out $80-$100 for a new one on eBay. :-/
                                      The RiddleTV guy (from post #28 on this page) said to check the SMD capacitors at 2H08 and 2H09. Heck, that location isn't even there!
                                      It must be an unmarked location, but the manual's only reference is in the parts revision list. There's no diagram of the entire scaler board. Or am I too dumb to find it?
                                      • broksonic
                                        • Apr 2012
                                        • 25
                                        • usa
                                        #39
                                        It is rather confusing (manual for scaler board).
                                        I finally got a download using safari.
                                        I have been searching for a different diagram too (bing, google, even ask) with no luck.
                                        Got my friends/co-workers watching the e-recycling for a possible replacement as well as watching e-bay.
                                        Unless someone else has an idea i see no other option than scaler replacement right now.
                                          16vdc to the scaler board, and comes out as 12v by the busking switching regulator. there are so many regulator, switching power supplies on this scaler board to check.
                                          • Elecfronicsssss
                                            DA0NJJMBAG0 charging light blinks
                                            by Elecfronicsssss
                                            Laptop motherboard DA0NJJMBAG0
                                            PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                            CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                            GUIDE ME WITH THE PROBLEM..
                                            SUMMARY-
                                            1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                            2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                            05-12-2025, 02:32 AM
                                          • icareservicezone
                                            Synology DS918+ blue light blink
                                            by icareservicezone
                                            Synology DS918+
                                            Model name : GDI41L2
                                            p/N: 08-06GDI4116
                                            Version: V1.6
                                            Problem : blue light blink...
                                            05-24-2025, 11:53 PM
                                          • mecha1166
                                            XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                                            by mecha1166
                                            I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                                            07-01-2024, 05:47 PM
                                          • djordje
                                            Philips 55 oled 804/12 red light blink
                                            by djordje
                                            Hello all,
                                            I have Philips Oled 55 (804/12) with black screen and red light blink.
                                            I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                            Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                            When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                            My questions is what should i do next...
                                            01-03-2025, 04:00 PM
                                          • apostsamking
                                            latitude 3350 blink 1 white light on
                                            by apostsamking
                                            Pls I have latitude 3350 laptop and it stop working. I realize that anytime I press the power button it powers on blink 1 white light on and off. I flash bios but the same problem. I realize that the 3.3v that's on the bios chip is not stable. It goes on and off. But when I remove the bios chip from the board power is stable. I have change the bios chip still the same problem. What should I do.
                                            05-30-2024, 02:02 AM
