Akai LCT3201AD
  • Tornath
    • Apr 2009
    • 8
    Akai LCT3201AD
    Got this TV for free because the person who had it couldn't figure out what needed to be fixed on it. After opening it up, I found a total of 8 bad caps.
    Power Supply
    2 CapXon KF series 220uF 25v 105 temp
    Tboard
    6 Decon SAII series 220uF 16v 85 temp
    Based on the little info I can find about these two capacitors, I think I've found replacements, but I wanted to get some input on quality and to see if I had the right replacements.
    For the CapXon caps
    http://search.digikey.com/scripts/Dk...me=493-3277-ND
    and for the Decon caps
    http://search.digikey.com/scripts/Dk...me=493-1041-ND
    But I notice they only have 2 of the Decon replacement in stock, so what would be a good quality alternative that I could use?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Akai LCT3201AD
    RAT POISON CAPS!
    First look up ESR & Ripple specs for old caps. - TT series won't do it for KF.
    Second, never buy 85C caps. They last 1/4 as long.
    [Note: For all practical purposes: Impedance = ESR at 100kHz.]
    Want ESR the same or less.
    Want Ripple the same or more.
    SAII is a GP cap but, for what it is, it has pretty good ripple.
    Only -good- replacement I know of [for the 220uF 16v] without going to an 8mm cap is Chemicon LXZ.
    [Those come up so often I buy 100+ at a time.]
    You figure out the KF replacement and tell us - so we know you 'get it'.
    Mann-Made Global Warming.
    - Dr Seuss
    • Tornath
      • Apr 2009
      • 8
      Re: Akai LCT3201AD
      So based on what you said, these are the replacements I'm looking at now.
      For CapXon
      http://search.digikey.com/scripts/Dk...me=565-1546-ND
      For Decon
      http://search.digikey.com/scripts/Dk...me=565-1927-ND
      That right?
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Re: Akai LCT3201AD
        What were the symptoms exactly?
        Can we get pictures maybe?
        I had an AKAI where it's only problem was the power jack.The capxon's got to go. lol
        • Tornath
          • Apr 2009
          • 8
          Re: Akai LCT3201AD
          Symptoms were:
          When plugged into a power source the red standby light would turn on. When you hit power the green light would flash for the briefest of moments then turn red again. The unit would not turn on for any reason and when attempting to turn it on, there would be a slight clicking and high pitched whine from the Power suppliy board.
          Here are pic's of the affected boards and where the caps were removed.
          Tboard
          The Labels on the locations are CE3, CE14, CE25, CE29, CE16, and CE4. They are all Decon Caps.
          Power supply
          The Labels on these locations are EC12 and EC15. They are located under a heatsink and are the CapXon caps.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: Akai LCT3201AD
            Those look like good choices for the stated caps.
            On Akai you should recap the whole power supply board.
            Those Megmeet PSUs run very hot and the cheap Chinese caps just don't last.
            [Mine had some 10mm 1000uF 16v that I replaced with a higher grade 8mm 1000uF 16v due to availability at the time. That might still be the case.]
            There are usually a few larger caps on the main board as well.
            At least do the 8mm and up as a preventive measure.
            I replaced everything on the power board and everything 6.3mm and up -and/or- 470uF and over on the other boards in mine.
            .. That was probably over-kill but I didn't wanna take it apart again later..
            - Dr Seuss
            • Dgtech
              E. Technician
              • Apr 2009
              • 1462
              • Steeler
              Re: Akai LCT3201AD
              I usually change my caps one by one so I dont get confused. I hope you know what goes where.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Re: Akai LCT3201AD
                Cap Maps.
                Take a snap-shot, make it big and print it, mark right on it..
                ~~~~ Don't forget to mark polarity too........
                Silk screens are not always correct...
                - Dr Seuss
                • Tornath
                  • Apr 2009
                  • 8
                  Re: Akai LCT3201AD
                  All the markings on the board for polarity were correct. I checked them as I took the caps off, and I also wrote down what type of cap goes in what spot as I removed them as the 2 power supply caps are the same size and all of the Tboard caps are the exact same as well.
                  • brad2157
                    Decon SH PET Capacitors for “Klipsch The Fives”
                    by brad2157
                    I’m working on re-capping the power board caps on a Klipsch The Fives audio speaker system. I can’t locate a replacement for these original caps that are labeled “Decon SH PET”. I have three of these on the board with the electrolytics. They are supposed to be a film type capacitor, but they look like a radial mount electrolytic. Everything I find they look completely different, usually a square type body. The two values I need are 16V 470uF and 35V 47uF. I’ve got all the other caps in my cart already from Mouser, so if there’s a replacement there, I would prefer to order from...
                    10-21-2024, 09:47 PM
                  • Dannyx
                    How I "fixed" the display on an Akai LT-3220AD TV
                    by Dannyx
                    Good day folks. I thought I'd share with you something I did today, just for a laugh and for a bit of a discussion, since I'm still not entirely convinced what happened there.
                    I found an Akai LT-3220AD TV in the dumpster - literally - so me and my colleague brought it back into the shop and dusted it off a bit to see if someone maybe gave up too soon.
                    Long story short: backlight came on but had no picture. My colleague attempted to reprogram the SPI chip but it didn't change anything, so we concluded it must be the panel that's faulty, especially after reading about it...
                    01-29-2024, 10:12 AM
                  • Genaugmen
                    Akai MPK 261
                    by Genaugmen
                    I got this akai MPK 261. Had no power from USB. Optional Power adapter caused some light smoking, so unplugged and disassemble to get to the main board. There are two surface mount inductors near the power input. One look obviously damaged, removed both for replacement. Then there's this IC a few components away (pictured) that I can't identify. I've done plenty of plenty of surface mount component work, so replacing it isn't a problem. Any insight into what this could be would be greatly appreciated....
                    09-17-2023, 01:17 PM
                  • sumilumi
                    700mv ripple on Akai Sampler linear supply
                    by sumilumi
                    Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
                    I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
                    On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple...
                    01-02-2022, 10:12 AM
                  • Alfieh
                    NAD C320BEE repair possibly bad capacitors
                    by Alfieh
                    hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
                    recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
                    11-19-2024, 04:55 PM
