Toshiba 17mb65s-s
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Toshiba 17mb65s-s
    Typo: 17MB65S-3
    TV works great but no sound from speakers. Sound does come from the audio jack so no need to replace the audio IC. Done some research on this issue and the next issue can be those ceramic caps. Can someone tell me their values or provide a schematic?
    See red:
    Yellow for audio ic:
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8214
    Re: Toshiba 17mb65s-s
    Look for the obvious. See if the caps you circled are shorted, check with an oscilloscope where you lose the audio. Maybe the headphone jack is bad etc.
    • speedypro
      • Feb 2013
      • 561
      • United Kingdom
      Thanks but headphone jack is ok. Two caps are 100% shorted.
        Looks like an RC snubber, and since each channel is the same frequency then they're likely to all be the same value. A multimeter may be able to measure them.
        • speedypro
          • Feb 2013
          • 561
          • United Kingdom
          Originally posted by tom66
          Looks like an RC snubber...
          What is that?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No no no no no ! Factory reset the Tv and should work lol
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Trust me common issue on them boards is the firmware glitches out then no audio on anything, go to first time installation and reset it and re-tune ect should work ive done a few of these.
              • speedypro
                • Feb 2013
                • 561
                • United Kingdom
                I saw your videos on YouTube. Nice. I'll try this tomorrow as I've now left work.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Cheers I had that one needed a re-flow but I did first time install is so probably firmware glitching so inconclusive. I did a 37" Toshiba same mobo the other day no sound all it needed was a reset and done a few before. Give it a try and let us know buddy
                    Originally posted by speedypro
                    What is that?
                    It removes higher frequency components in the output signal from the class-D amp by shunting them to ground via a resistor. Energy is dissipated in that resistor.
                      I think you are see the DCR of the speakers, remove the speakers connector and check again.
                      What id the P/N of that class D chip? The headphone output is probably driven by small OPAMPS.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Correct the Amp for the ear phone ports in integrated in the main Cpu but the amp is driven separately as you know. However the firmware on these always seems to mess up and the Tv no longer runs the main speaker amp a simple reset should fix it in my case anyway.
                        • michael dranfield
                          • Jan 2016
                          • 232
                          • England
                          If this is a 40 inch set before changing anything try doing a first time installation re tune, I dont know why but this usually cures the fault you have, if its not a 40 inch you may have to do a factory reset.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Badically what I said... But it doesnt matter I have done first time installs on a 37" and 32" and worked fine why would it make a difference ? Same board, same firmware yes 40" plus use different amps but still applies too all. This is a 46" I think too.
                            • speedypro
                              • Feb 2013
                              • 561
                              • United Kingdom
                              Yes! factory reset worked! Thanks!
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Awesome told you it would Now just recap the Psu too because bad caps are common on them
                                • speedypro
                                  • Feb 2013
                                  • 561
                                  • United Kingdom
                                  Will do
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    BTW what psu is used in this and what size is it ?
                                      09-06-2024, 05:27 AM
                                    • ChaosLegionnaire
                                      by ChaosLegionnaire
                                      09-13-2022, 09:02 AM
                                      09-06-2024, 05:59 AM
                                      Toshiba Satellite L635-10K Notebook Specification for Upgrade or Repair
                                      This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
