HP22 2sec to black CCFL to LED conversion
  • steves7839
    • Nov 2014
    • 200
    I installed two LED strips with the included driver into this 22" monitor. The screen is nice and bright now. But no menu or sound.
    Before surgery the monitor showed a welcome "no source connected" screen for about two seconds. Most of the display around the welcome screen was dark. It then powered off the backlight.
    If the display is now all white, does that mean no video signal is getting to the LCD panel? Or maybe I just put the polarizer, glass plate and LCD panel back together in the wrong order.
    Suggestions?
    The model number is W22; the panel is Chi Mei M220Z1-L01
  • boyebaran
    • Sep 2015
    • 247
    • iran
    Re: HP22 2sec to black CCFL to LED conversion
    hi
    you must disable protecting by controler ic .
    please upload clear picture from ic or send part number.
    protect means when one of component have problem(ccfl-high voltage and.....)ccfl controller ic shutdown power supply for avoid further damage.
    you disconnected ccfl from board and ic not sense ccfl and gone to protect
      Did you verify that LVDS cable at the LCD PANEL is secure back in properly when you put the unit back together? You may also have to verify that you do have either 5V or 12V at the smd fuse on the T-CON on the LCD panel assembly or not.
      • steves7839
        • Nov 2014
        • 200
        Thanks for the replies, guys!
        Here's a picture of the main board; is this the controller IC you mentioned? Or is it on the power supply near the inverter section?
        BudM, the T-Con appears to be incorporated in the circuit board attached to the LCD panel. There's no twisted-pair LVDS cable, just a flat cable to that board from the main board.
        Also, I forced the backlight on using a 3.2V from the main board, but have not connected the dimmer line to the new LED driver board. I guess that means no brightness control.
          I know that the T-CON is integrated to the LCD panel assembly, that flat ribbon cable is the LVDS cable which also provide either 5V or 12V to run the T-CON board and there is connector on that integrated T-CON board. BTW: LVDS cable does not have to be twisted pair, just about all monitor and TV use flat cable these days.
          There is no error feedback signal used in this monitor to tell the logic board to go into shutdown if the backlight circuit detects the error, so it at this point the inverter circuit does not matter any more and the power going to the inverter section should be disconnected.
          So do you have 5V or 12V at the T-CON or not?
          • boyebaran
            • Sep 2015
            • 247
            • iran
            Originally posted by boyebaran
            hi
            ic placed under inverter board.
            • Dumah Brazorf
              • Jun 2013
              • 179
              • Italy
              Isn't backlight circuit independent from the image circuit?
              I mean, usually if backlight shuts off you can see the image on the screen anyway using a flash light.
              So probably the lcd is dead.
              Where did you hook the power for leds?
                That is correct! That is what I am trying to get through, there is no feedback from the backlights circuit to tell the main board to go into shutdown, that is why you can still see image on the screen using other light source when the backlights are not working.
                • steves7839
                  • Nov 2014
                  • 200
                  In the photo of the LVDS connector, the pin closest to U202 has 5.1V for the first minute or so. It then goes to 0 as the monitor's power LED goes from green to amber. There is no picture, even by flashlight.
                  In the other photo there is a solder blob next to C211. I don't remember seeing it there at first inspection. I soldered the wire for the LED backlight power to the open pad for U202 and jumpered from CN201-12 for the BL enable wire.
                  I will have to disassemble to check the voltage at the other end of the ribbon cable, so will do that tomorrow.
                  • Dumah Brazorf
                    • Jun 2013
                    • 179
                    • Italy
                    So are you powering that leds @5V? Aren't these kits work with 10V to 30V?
                    I don't think 5V line is beefy enough to power everything. You should power leds from the same line that serves the ccfl inverters.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Most likely it would be 12V used to supply the CCFL circuit. That 12V MUST be disconnected from the CCFL circuit. That is the supply that should be used to power the LED Driver Bd. Also, the BL ON/OFF and DIM control MUST be connected to the LED Driver Bd. and taken from the Main Bd. or where the CCFL circuitry was getting those signals. Short cuts don't work in these cases.
                      • steves7839
                        • Nov 2014
                        • 200
                        The LED power board in the kit accepts 10-30VDC. I am powering it with 12V from the main board and using 3.4V for enable. I don’t yet know where to connect the “dim” input on the LED power board.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          That appears normal. The power going to the T-con board should be OFF when the monitor's LED turns amber. But, if you still see a white image with the monitor's LED being green, then that means either the T-con is not getting proper signals from the logic board (due to dirty and/or misaligned LVDS cable) or due to bad inverter supplie(s) on the T-con board (though, I am not sure how you changing the CCFLs for LEDs would damage the T-con board's power supplies, so try re-seating the LVDS cable a few times and make sure its contacts are clean).
                          • Dumah Brazorf
                            • Jun 2013
                            • 179
                            • Italy
                            Check the 12V when on.
                            Disconnect temporarily the new backlight and check with a flashlight if there is image.
                            • steves7839
                              • Nov 2014
                              • 200
                              It's fixed. Once I reopened the panel I found the LVDS ribbon cable loose. I also connected BL Enable to the inverter enable signal.
                              Since I had no input connected, the display went dark and the unit's power LED went amber after a minute, normal behavior.
                              Thanks for the suggestions!
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                Good to hear you got it working!
                                  Glad to hear, as suggested in post #3 for what to check.
                                  • ttmi100x
                                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                    by ttmi100x
                                    Greetings everyone,
                                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                    Upon closer inspection...
                                    07-31-2024, 06:36 PM
                                    HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                    This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                    09-12-2024, 02:00 PM
                                    MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                                    This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                    09-12-2024, 01:58 PM
                                    Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                    This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    09-07-2024, 05:00 AM
                                    Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                    This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 04:10 AM
