Bush BPDP42HD2 Ysus kills Xsus
  • satinser
    • Oct 2012
    • 214
    • uk
    Original fault was 3 clicks on start up and back to standby. Found that one of ics on y buffer board had gone short circuit on 3 pins but no physical damage. Also xsus had blown 2 fets. Replaced the 2fets and tried again without buffer board which is on order and fets blew again. Now tried anaother xsus board which I had available and the 2 fets have now blown on that one too.
    Tested the ve voltage from ysus and found voltage is not stable and goes as high as 100v when it should be 55v so thats the cause of killing of xsus.
    Anybody any experience of this fault. Perhaps CRT MAN?
  • flocko
    • Nov 2012
    • 1121
    • uk
    Re: Bush BPDP42HD2 Ysus kills Xsus
    Sorry to say but all three X sus,Ysus Y buffer to be safe need to be changed as a set you will go round in circles otherwise, look up posts for BPDP42HD3 and PS42C450 same sets Flocko
      Ve is supposed to be about 100V you are probably confusing it with Va.
      • satinser
        • Oct 2012
        • 214
        • uk
        Thanks for both your replies. Have read your previous post (Flocko) regarding problems that you had with HD3 version of above TV. It would seem that the Ysus board is also faulty(even though fets test as ok)I originally believed it to be just the buffer and xsus. From similarity s with problems you experienced with your HD3 repair I will source a ysus board and once again replace the failed fets on xsus board. Will let you know how I get on. I just hope I dont have problems trying to source boards that dont themselves have faults. I have found great difficulty lately to get used buffer boards that dont have ics shorted even though there listed as ok!
        • flocko
          • Nov 2012
          • 1121
          • uk
          I have not seen or heard that anyone has had any luck repairing these boards, but please let us all know how it goes,on the Y buffers if fitted(there are two types) with the blue caps in the center and check the glue as this sometimes shorts Flocko
          • satinser
            • Oct 2012
            • 214
            • uk
            Yes will keep you informed. As regards to your comments regarding the repair of these boards are you referring to the xsus board? Received another ybuffer board today from another Ebay seller claiming item tested and working and once again tested shorted on 1 of the ics!
            As regards the Ybuffer for this model can anybody confirm that the LJ41-08594a which is fitted to the PS42C450B1W would be compatible. As the one fitted has the is LJ41-09470A but shares the same LJ92 number (01739a).
            • tw2005
              • Oct 2011
              • 6458
              LJ92-01739 Rev A - D will all work (board assembly number)
              LJ41-08594A & LJ41-09470A are PCB numbers so in other words the blank board.
              If you have a look at each you will notice the subtle differences e.g. the 2 large polyester caps now used in place of the SMD caps. The PCB has been modified for the through hole fitment hence the different number.
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                A faulty buffer-board with the 42C450 can damage a Y-SUS on these sets, they say a faulty Z-SUS will also....
                They recommend that all three are replaced--as a kit, problem for us lot is finding three known working boards--from different sources/sets!
                I have a number of boards from these sets, only one 'kit' that I know is good out of say, 4 sets of boards, that I'm hanging on to....
                TELEFIX
                • flocko
                  • Nov 2012
                  • 1121
                  • uk
                  As i have said before if you want to be safe change all three boards as a set, the part number that you need to match are the LJ92-xxxx on all boards, these are also fitted in the PS42Cxxx,Bush BPDP42HD2 and 3 and some philips sets, i cannot work out why there are so many bad boards out there, all the cracked screen PS42C i have parted out have all ways had good boards or have i just been lucky Flocko
                  • crt man
                    • Mar 2013
                    • 106
                    • England
                    Of the six I have done I have found no fault on the Ysus, only Ybuffer
                    which has shorted the Xsus FETS.
                    Personally I would not recommend running the set with any boards disconnected
                    I did it with one, and shorted the LVDS board I have found if the buffer
                    has one short then that only will be faulty, but it has three or more then it is likely to short the FETS on the Xsus
                    HTH
                    Alan.
                    • satinser
                      • Oct 2012
                      • 214
                      • uk
                      Appreciate your comments Allan but could you explain why running the ysus without buffer board attached still blew the fets on xsus board?
                      • crt man
                        • Mar 2013
                        • 106
                        • England
                        Hi
                        I think it is overloading the Xsus board, with one side of the screen connected and the other not.
                        If I pluck up the courage in the next couple of days then
                        I will disconnect the Y buffer from my test set,
                        and see if the the two FETS short on my board.
                        Alan.
                        • satinser
                          • Oct 2012
                          • 214
                          • uk
                          Thank you for that Alan! It would inspire me with more confidence to try the Xsus board that I have again replaced the 2 fets on when I finally manage to obtain an ybuffer board that hasnt got shorted ics!!
                          I once again received a ybuffer yesterday which again I was assured by the seller that all boards are tested prior dispatch which had 1 shorted ic.
                          I have ordered another such board today, trouble is my confidence levels of receiving a good board are at an all time low. Consequently, when it takes so long to obtain parts protracting the repair time you begin to lose face with the customer.
                          As a matter of interest have you ever had to replace any other components on blown xsus boards other than the 2 fets?
                            If you find IGBTs to be blowing constantly, I would replace the driver IC which drives them.
                            The fact that a Y-buffer can kill the X-main or vice versa is very odd, and hard to believe; there is no electrical connection between them inside the panel.
                            Something else might be going wrong like a faulty control board or maybe it doesn't handle bad X-main properly.
                            • tw2005
                              • Oct 2011
                              • 6458
                              I tried this on a C450 and replacing just the 2 IGBTs that blew did not work. They blew again and then I also killed my Y
                              • satinser
                                • Oct 2012
                                • 214
                                • uk
                                In a previous post from crtman it was mentioned that in 3 of the 6 that he had repaired the fets on xsus board had blown. It was also mentioned that the 2 fets were replaced. I would be interested to know whether in those cases replacement of the fets was all that was required to repair those xsus boards. It would appear that with this particular Samsung model the only way to repair it is by using 3 good boards Ysus,Xsus and Ybuffer or you run the risk of blowing the xsus fets again. Diagnostic checks without Ybuffer also apparently runs the risk of blowing fets on xsus as in my case.
                                • crt man
                                  • Mar 2013
                                  • 106
                                  • England
                                  Hi
                                  In the cases of the blown FETS all I did was replace them,and the board
                                  worked perfectly. The only thing I found was that if the Y buffer had one
                                  short on a IC then only the Y buffer needed replacing, but if there were
                                  more than one short on the IC then the FETS would short.
                                  Alan.
                                  PS I am still working up the courage to disconnect the Y buffer on my test set and see what happens with the FETS.
                                  • satinser
                                    • Oct 2012
                                    • 214
                                    • uk
                                    Go on go for it!!
                                    • crt man
                                      • Mar 2013
                                      • 106
                                      • England
                                      Go on go for it!!
                                      Well I did, and the worst thing is I knew what was going to
                                      happen. Disconnecting the Y buffer on the set shorts the
                                      FETS on the Xsus.
                                      So now that is another board to repair
                                      Alan.
                                        Wow, that is a surprise. I am guessing that is bad firmware design rather than an electronic problem with the TV. Sorry to hear about your board though!
                                        • legg
                                          LG 42PC3 buffer output doesn't follow YSUS
                                          by legg
                                          LG42PC3D -UD originally with green lamp but no display or audio.
                                          Owner says was working, then went 'pop'.
                                          All 5V caps bulging. replaced.
                                          All PSU output voltages within spec but -Vy is low on YSUS.
                                          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                          eventually shorts DG. Replaced all 3 - -Vy now OK.
                                          Y scan buffer test point does not follow YSUS output below -50V
                                          Note: This unit seems to expect YSUS output to park at -Vy in between
                                          drive signal pattern periods. A replacement drive signal board confirms this....
                                          11-18-2021, 11:49 AM
                                        • FlailingEngineer
                                          Help with Bush Tv (Vestel 17mb95m Mainboard)
                                          by FlailingEngineer
                                          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                          05-31-2023, 06:52 AM
                                        • Truncatedhose
                                          Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                                          by Truncatedhose
                                          Greetings all!
                                          Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                                          Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                                          07-04-2018, 10:59 AM
                                        • tyler123456
                                          Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                                          by tyler123456
                                          Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                                          I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                                          I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                                          Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                                          Anyone...
                                          08-16-2024, 12:51 PM
                                        • zwarder
                                          eax61319402 50PJ350 YSUS
                                          by zwarder
                                          Hi
                                          Had shorted YSUS
                                          Q24 RPJ63F3
                                          C726 cap
                                          Q11 K3667
                                          R528 & R529 2.2 ohm
                                          replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
                                          ZSUS is also good as far as I can tell
                                          Anyone could help me out on this one
                                          10-23-2023, 08:11 AM
