Gigabyte 8S661FXM-RZ
  • davmax
    • Dec 2005
    • 899
    This came in with badcaps in PS and VRM input. No boot.
    Replaced caps still no boot. Problem is in VRM\CPU area. VRM output 0.57V with no CPU present but fan connected. 0.06V with CPU present. Have checked for shorted caps, none. Have checked for shorted or melted MOSFETs , none.
    I suspect CPU is burned fan and heatsink clogged with dirt (now clean) there appear to be some hot spot colours on the top of the CPU, green at centre flairing out to black then brown, like a spark burn.
    I expected the VRM output to be higher with no CPU load. Is VRM output stable with no load??? What voltage should be expected??
    CPU is 478 Celeron 2.4Ghz. Vcore spec 1.25-1.4
    Comment please
    Gigabyte EP45-DS3L Ultra Reliable (Power saver)
    Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    160Gb WD eSATAII Server grade for backup.
    Samsung 18x DVD writer
    Pioneer 16x DVD writer + 6x Dual layer
    33 way card reader
    Windows XP Pro SP3
    Thermaltake Matrix case with 430W Silent Power
    17" Benq FP737s LCD monitor
    HP Officejet Pro K5300 with refillable tanks
  • davmax
    • Dec 2005
    • 899
    Re: Gigabyte 8S661FXM-RZ
    Forgot to state that 12Volt supply to VRM is OK
    Nvidia 8500GT 256Mb
    33 way card reader
    Windows XP Pro SP3
    • davmax
      • Dec 2005
      • 899
      I suspect that removing the CPU is not a good test of VRM in that I believe the CPU is involved in setting the core voltage. Is this right? I do not want to rush out and get another CPU without some confirmation that VRM is OK as components suggest.
      Nvidia 8500GT 256Mb
      33 way card reader
      Windows XP Pro SP3
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        measure cpu core across the mlcc on the underside.
        best way to detect shorted core.
        vrm output is set by vid pins.
        different steppings need different vcore so intel sets up vid pins to suit.
        • davmax
          • Dec 2005
          • 899
          kc8adu thanks.
          I have been measuring core at VRM output caps. I guess this is close. It has been effective with working systems. Certainly pulled low by CPU in this case.
          I think I read you correctly that CPU sets voltage via VID pins.
          It therefore appears CPU is toast. Do you agree?
          Nvidia 8500GT 256Mb
          33 way card reader
          Windows XP Pro SP3
          • starfury1
            • May 2006
            • 1256
            if I understand about VRM from what I read in a zillion page pdf on it
            yep the cpu tells it via vid what voltage it requires
            Anyway a quick search found a wiki
            The correct supply voltage is communicated by the microprocessor to the VRM at startup via a number of bits called VID (voltage identificator). In particular, the VRM initially provides a standard supply voltage to the VID logic, which is the part of the processor whose only aim is to then send the VID to the VRM. When the VRM has received the VID identifying the required supply voltage, it starts acting as a voltage regulator, providing the required constant voltage supply to the processor.
            Wikihere
            not much else of any real use there...intel link maybe
            HTH and yeah I'll leave it to KC8 if its stuffed or not
            (not the guru here, my guess probably)
            Cheers Davmax..and were you been hiding? all
            You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
            • shadow
              • Feb 2007
              • 732
              That really does not sound healthy! It seems like something has been getting whatever is at the black and brown coloured areas quite hot. My guess would be that the CPU is toast. A sure way to find out is to test the CPU in a known working motherboard, although a lot of the time this is not possible. A picture may be helpful if possible.
              • starfury1
                • May 2006
                • 1256
                Akor posted a VRM checking procedure (how applicable it is don't know, possibly you have already done this) and the other thing that crossed my mind was Possibly The MB my have become a CPU killer
                there is a thread Identifying a CPU killer (ahead of time) help
                maybe you have all read done this too but thought Id add it anyway....
                your dead (clogged) fan and over heated CPU, might really be it most likely.
                Another idea is to possibly identify the VRM controller chip (possibly support chips) and grab the pdf for it so you can get a better idea of how the VRM is put together on that PCB.
                Like I said, not the guru... just trying to help in my own small way
                cheers all
                • davmax
                  • Dec 2005
                  • 899
                  starfury1. Many thanks for links. Useful. I have now identified the problem as VRM failure and I am replacing the motherboard. Getting a better one with Intel chipset and dual mem controller, better for customer.
                  Nvidia 8500GT 256Mb
                  33 way card reader
                  Windows XP Pro SP3
                  • starfury1
                    • May 2006
                    • 1256
                    No worries Daxmax glad I was of some help
                    Cheers mate
                    correction for my above post..."already done this"...DOH!
                    • krazykev64
                      • Feb 2009
                      • 49
                      i also got one of these and i can see for sure that the caps are gone as three are bulged. as a matter of interest was the three caps between the agp slot and heatsink mounting made by rubycon or have they been replaced in the past. can all caps be purchased from maplins?
                      • kiddznet
                        • Jul 2010
                        • 176
                        I have an identical problem with a 8s661fxm-rz socket 478 board
                        Did anyone resolve this one?
                        939 DualCore AMD Opteron, 1800 MHz (9 x 200)
                        Abit AN8 / Fatal1ty AN8 SLI Series
                        3072 MB (PC3200 DDR SDRAM)
                        ATI Radeon HD 4300/4500 Series (1024 MB
                        Lian LI Aluminium mesh case
                        • DynaxSC
                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                          by DynaxSC
                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                          General test conditions:
                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                          What is wrong:
                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                          03-21-2025, 06:23 PM
                          Thermal pad thickness for various laptop GPU / Graphics Cards
                          ASUS Dual RTX 2070 OC 8GB
                          ASUS ROG STRIX RTX 3080 OC
                          ASUS ROG STRIX RTX 3090
                          ASUS TUF Gaming RTX 3080 OC Edition
                          ASUS TUF GTX 1660 S-O6G GAMING
                          EVGA RTX 3060 Ti XC GAMING 8GB
                          EVGA RTX 3060 XC GAMING 12GB GDDR6
                          EVGA RTX 3080 FTW3 ULTRA GAMING
                          EVGA RTX 3080 TI FTW3 ULTRA GAMING
                          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                          Gainward RTX 2080 Phoenix GS Specs
                          Gainward RTX 3070 Phoenix 8GB
                          Gainward RTX 3080 Ti Phoenix
                          GIGABYTE AORUS RTX 3080 MASTER 10G
                          02-09-2024, 08:08 AM
                          Gigabyte Notebook Specification for Upgrade or Repair
                          This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...
                          09-07-2024, 07:19 AM
                          Gigabyte G series G5 MF-5 Notebook Specification for Upgrade or Repair
                          This specification for the Gigabyte G series G5 MF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 MF-5 boardview and G5 MF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
                          Gigabyte AERO 16 XE5-73UK948HP Notebook Specification for Upgrade or Repair
                          This specification for the Gigabyte AERO 16 XE5-73UK948HP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 XE5-73UK948HP boardview and 16 XE5-73UK948HP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
