help!! asus x542uq don't turn on and do nothing
  • marcelofct
    • May 2019
    • 122
    • chile
    hello guys i need your help with this .
    I did the measurement on the connector power and I have 19v, 5 and 3 volts too, the memory voltage does not.
    motherborad does nothing, does not heat up, does not turn on power light. please help me with this problem
    attached boardview
    thanks !!
  • emestee
    • Dec 2019
    • 228
    • Bulgaria
    Re: help!! asus x542uq don't turn on and do nothing
    Check CMOS battery voltage, and the presence of 3.3V on the power button first. Please see the beginner tutorial.
    • marcelofct
      • May 2019
      • 122
      • chile
      both voltages are ok ... i read the tutorial last year xD , but i will read again
      another thig to do or check ?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        RTCRST# and SRTCRST# needs to be checked. Only cmos battery good will not do the job.
        • marcelofct
          • May 2019
          • 122
          • chile
          i'll check in a few hours ,
          I will comment soon
          thanks
          • marcelofct
            • May 2019
            • 122
            • chile
            I will comment soon
            thanks
            I have the voltages
            RTCRST#3v and SRTCRST# 3v
            now what could it be, bios?
            • emestee
              • Dec 2019
              • 228
              • Bulgaria
              Could be, yes. Check several adjacent GPIO pins on the EC - are they also 3.3v? If so, it may very well be the case that the EC cant read firmware and is in initial state. Check the power on the flash chip. If you have an oscilloscope, put a probe on SI/SO signals and see if there is exchange of data.
              This all, of course, assuming that the EC doesn't have its own flash memory. I can't open the boardview because openboardview crashes on asus .fz files for some reason.
              • marcelofct
                • May 2019
                • 122
                • chile
                yes i have those voltages 3v on every cap i tested i need to check the kbc.
                the model is it8995e-128 , i havent osciloscope what do you recomend me now ?
                • emestee
                  • Dec 2019
                  • 228
                  • Bulgaria
                  Unfortunately this KBC has built in flash. You need to have a SIO programmer if you want to flash it.
                  But let's get back a little. When you press the power button, does the voltage drop to 0v?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    RSMRST# present??
                    • marcelofct
                      • May 2019
                      • 122
                      • chile
                      yes , it does , push power button and voltage drop to 0v , now what i do ? please help me
                      RSMRST# present??
                      no , isn't present , on this motherboard boardview says PM_RSMRST# AND PM_RSMRST#_PCH
                      what voltage it is ?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        If RSMRST# is not present, mb is not going to turn on. KBC sends this signal to pch first and then pm_pwrtbtn and pch in turn starts SLP_S3/S4
                        • marcelofct
                          • May 2019
                          • 122
                          • chile
                          i just checked and no signal , then i have to flash kbc firmware o i can try bios ?
                          if is kbc im done
                          • emestee
                            • Dec 2019
                            • 228
                            • Bulgaria
                            if is kbc im done
                            I'd check the KBC oscillator and all voltages on it, in particular the 3v LDO coming out of the charger and the ACOK signal...
                            • marcelofct
                              • May 2019
                              • 122
                              • chile
                              I'd check the KBC oscillator and all voltages on it :
                              if you mean check with oscilloscope i haven't one of those ,
                              and i have ac ok signal 6v on that ,
                              flash bios or is nothing more to do thank a lot for your support
                              • stingerchamp
                                • Sep 2020
                                • 425
                                • Pakistan
                                Where did you measure acok signal 6v?
                                Check again it must be below 3
                                • Udara Umayanga
                                  • May 2020
                                  • 11
                                  • Sri Lanka
                                  Hi friend,
                                  I have same can't power on.. It have smone short in chager. Now it solved. But can't find what is the problem..pleace help me..
                                  If you have diagrame please send me
                                  Thanks,
                                  Udara
                                  • mon2
                                    • Dec 2019
                                    • 14000
                                    Have only boardview file for x542uq 2.0 logic board. Will that help ?
                                      ASUS VivoBook X542UQ-GO019T Notebook 15 Specification for Upgrade or Repair
                                      This specification for the ASUS VivoBook X542UQ-GO019T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X542UQ-GO019T boardview and X542UQ-GO019T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 08:00 AM
                                      ASUS VivoBook X542UQ-DM279 Notebook Specification for Upgrade or Repair
                                      This specification for the ASUS VivoBook X542UQ-DM279 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X542UQ-DM279 boardview and X542UQ-DM279 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 06:40 AM
                                      ASUS VivoBook X542UQ-GQ292T Notebook Specification for Upgrade or Repair
                                      This specification for the ASUS VivoBook X542UQ-GQ292T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X542UQ-GQ292T boardview and X542UQ-GQ292T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 06:45 AM
                                      ASUS VivoBook X542UQ-DM234T Notebook 15 Specification for Upgrade or Repair
                                      This specification for the ASUS VivoBook X542UQ-DM234T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X542UQ-DM234T boardview and X542UQ-DM234T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 06:08 AM
                                      ASUS VivoBook X542UQ-DM071T Notebook 15 Specification for Upgrade or Repair
                                      This specification for the ASUS VivoBook X542UQ-DM071T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X542UQ-DM071T boardview and X542UQ-DM071T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 06:02 AM
