Saving a Vizio 50" Plasma VP50HDTV10A from the recycle bin
  • WickedPete
    • Apr 2013
    • 12
    Hello. Newbie here. I'm trying to get a Vizio VP50HDTV10A working. This is a little long but I wanted to be detailed.
    Background on the TV: – FREE - from Craigslist, so the only thing I have at stake here are time and materials. I answered an ad and picked it up from a young professional male, 20 minute drive each way, who told me it stopped turning on. As soon as I got home I opened the back and noticed 10 popped capacitors on the power supply board right away. At that point I think, woo-hoo, this might be easy. I did not bother plug the unit in at the time because with all those bad caps I thought it wouldn't do much if I did, and it was 10pm and I did not want to get started on anything and wind up awake at 2am working on it. I'll put pictures of some of the obviously bad capacitors. [Popped 1, Popped 2, and Popped 3]
    Quick Background on me: Amateur Mr Fix-It. I have a soldering iron, a solder sucker, a cheap multi-meter.... and I'm not afraid to use them. I got started in this by figuring out how to fix a tv about three months ago when my neighbor's 2008 Samsung LCD stopped turning on. He just went and bought a new HDTV and then gave me that “old” Samsung to tinker with. A Google search, a youtube video, a trip to an electronics parts store, and 4 capacitors later I had a working like new LCD tv. (Gave it to a different, needy neighbor who did not have a high def tv.) That success peaked my interest. Later, I got stumped on an early Pioneer Plasma (pre-hdmi) but redeemed myself repairing a Polaroid 32” LCD. (Sold it for $100 bucks on Craigslist) Now I have this Vizio that is actually a very nice, big 50” plasma that I'd really like to keep alive on this earth (And keep period!) for several more years before the recycle company gets it.
    Back to the Vizio VP50HDTV10A at hand: The next day I looked to find the popped caps were 9 Samwha 3300uf 10V and one Samwha 1000uf 10V. I went to my local electronics store and they had a 1000uf 10V in stock and only 4 of the 3300uf's I needed so I skipped those and ordered them all online because they're cheaper that way, and I'd have had to order some of them so I might as well order all of them. I ordered a brand I read was a good one on a couple websites. What I got is Rubycon 3300uf 16V (instead of the 10V) from a supplier (not ebay!) as a replacement because I heard that higher voltage is better as long as they uf is the same and they fit in the location. AND, they were on sale for 59 cents each. Now, come to find out what I ordered was PK series which are not low ESR. I had not heard of ESR when I'd ordered them. I'd heard of ripple current, of which the 16V caps were higher in so I am thinking that is better, but I did not know of ESR. * I had not been to badcaps * I am thinking here that ESR will relate to the life of the capacitors in this application and that having 16V in place of the 10 might help in that area as well. Whatever the case, I am hoping the caps I got will work for a while at least. This would allow me to move forward and replace those caps with the proper ones later.
    I put the 10 new capacitors on the power supply board in and plugged in the TV. There was immediately a fast double click followed a few seconds later by one more click. Then I pressed the power button and there was the same quick double click and a faint buzzing.... but no image when I pressed the menu button.
    Now that there was at least some power I could get the multimeter out and see where to go from here.
    Lable says:
    Va 59V
    Vs 193V
    Measured at the various pin out locations on the power supply board
    Va 64V
    Vs 179.5V
    I tried to use the adjustment “screw” to increase the Vs to closer to spec but in ¼ turn (at what appears to be “max”) there was a pop like a circuit breaker not a pop like a blown something and everything went dead. I turned the adjuster back and unplugged and then plugged back in the power and it was back to the same start up. I tried the adjuster one more time with the same result and again, unplugging re-set whatever it was and I did not touch the adjustment any further. I re measured the Vs's and got the same numbers.
    I turned on the set and left it for ten minuted and touched the heat sinks. I'll post a picture [WarmCool1] with the results. Orange is noticeably warm, blue is noticeably still cool, and blue+orange is not noticeably either.
    There is a small board with 4 led's that light up differently then end up with alternate lights lit. I'll put a picture. [Lights1]
    Service manual was easily found on line, but some of what it talks about I personally cant necessarily locate what they are referring to on the unit. Doesn't mean it's not there, just I'm not getting it.
    So, where do I go from here? If you need pics of something just let me know. If I need to test something, I need a quick basic lesson how to do it, or to be pointed in the right direction to find out.
    A thanks to you all in advance for your help.
    Re: Saving a Vizio 50" Plasma VP50HDTV10A from the recycle bin
    Any chance that "pop" you are hearing is from the speakers? To confirm, try unplugging them from the main board. Trace the wires. I've had this happen on some LG based plasmas when the power supply suddenly cuts out.
    Your low Vs and high Va is worrying. First, you should get Va to the specification, this is important because too high of a Va can damage the plasma panel itself. Then, you should try setting Vs. If the PSU cuts out, unplug the cable assembly going to the Y-sustain. This is the large board on the left hand side in your photo.
    • WickedPete
      • Apr 2013
      • 12
      Ok, thanks for the heads up on the Va. I used the adjuster and it's now at 59.1V. Vs I was able to carefully get to about 185-6V and then it pop's off if I go any more. Yes, popping sound just might be coming thru the speakers. Clicking and slight humm are definitely on the board. I am meeting friends for dinner and will try and unplug the board on the left when I get home later.
      Thank You. Your input is appreciated, as is your "hobby of keeping things out of landfills"! Similar here.
      P.S. - The tgohome site is where I came accross the service manual for this. That site is a GREAT resource and if it's yours, cheers to you!
        185V should be enough for a picture. It's definitely quite low, but it's not your fault at the moment. Low Vs generally causes stuck dark pixels or a purple-pink tint to the image, not no image.
        Yes, that is my site. I'm glad it was of use to you, although, Vizio service manuals aren't generally much good. The plasma panel in this set is made by LG Electronics. You can find the manual for the panel module PDP50X4 here. http://www.tgohome.com/ServiceManual...&Search=Submit... which will help you a lot more than the near useless Vizio manual...
        • WickedPete
          • Apr 2013
          • 12
          Ok, so I unplugged cables from the board on the left. (Which is I believe the Ysus, correct?) There are three cables, one with many wires coming from the power supply board, one leaving the Ysus going over the power board accross the whole unit and plugging into the Zsus, and another one coming from the power supply board to the Ysus but this one only has a few wires.
          In short, other than hearing things lose power, not much happened. No picture came up of any kind or lights came on, that's for sure.
          On another note, that LG manual looks WAY better than the Vizeo one. I only had time to skim over it and not really do much with it. I have a wedding to attend this afternoon and evening and will be back at trying to fix the TV tomorrow. I'll give you another update then.
          • WickedPete
            • Apr 2013
            • 12
            Newest symptom: I get a "brightning" of the screen, so I assume there's power going to something it should. The screen has blotches of grey and black around the whole screen in random pattern like camoflage. Also there are blue sparkles that flash all over it as well. No "Menu" and no start up image, but something is happening. As long as that does not mean the screen is bad, I'll take it as progress.
              Sounds like bad Z-sustain.
              • WickedPete
                • Apr 2013
                • 12
                A second person with knowledge of such things mentioned the Z sustain as well so I started looking online for a replacement board.
                In my search I actually found a place that has one about 1/2 hour drive from me, and better yet they will take some boards I have out of a Samsung plasma in trade. So no waiting for shipping and no cost but the trade of parts. When I put the replacement in I will update the results.
                • WickedPete
                  • Apr 2013
                  • 12
                  I swaped the Z sustain board out for a replacement and still have the blotchy image. [Blotchy 1, Blotchy2] Bad replacement board or different issue? The only other thing that might be noteworthy is the sticker on the panel says the Vs calls for 198V and I'm getting 188-89V at the board. I would think that would still give me something of an image...
                    You should adjust Vs on the power board to the PANEL sticker rating, not to any specification in any manual, because it varies with each and every plasma panel.
                    There are also test points for Vzbias on the Z-sus, and -Vy, Vsc etc. on the Y-sus.
                    • tbarton
                      • Nov 2010
                      • 2
                      Did you ever get it working? If so, what was the solution? Thanks
                      • tbarton
                        • Nov 2010
                        • 2
                        Hi, I also have a Vizio VP50HDTV10A that I am trying to fix. I am new at this. The problem is that the remote control is not operating the TV. I have replaced the remote with a new vizio remote - did not solve the problem. I used a camera to verify that the remote is sending IR signal. I tried to program 2 other universal remotes to operate the tv, they did not work. So, I am fairly certain the problem is in the TV. So, I replaced the IR board with a new one (hoping it would be a cheap and easy fix, but did not work). I examined the cable and connections between the IR board and the main board. Nothing obvious is wrong, but I did notice a kink in the cable, but it is pretty small and no holes in the insulation. I tested the IR board removed from the window in the TV casing to eliminate the possibility that the window was somehow blocked or that there was interference coming from the panel. A separate but possibly related problem is that the manual control buttons on the side of the TV for operating the power, channel up/down, volume up/down, input, etc are not working very well. Some buttons aren't working at all (channel up/down) and some work very well while some work intermittently (input). The cable that connects the IR board to the main board also connects the display board (which operates the manual buttons) to the main board. Since its the same cable I'm wondering if it might be the cable itself that is the problem (but like I mentioned earlier there are no obvious visible signs of damage). The final symptom is that when I power off the TV, the power LED blinks 10 times from green to amber before reaching constant amber. I am in the process of learning how to take voltage readings and I have a multimeter. Any help in diagnosing this problem would be much appreciated. Thanks.
                        • HNEAL76
                          • Sep 2013
                          • 1
                          I'm working on the same TV and it had the exact same caps blown. On the main board D3,D4, and D5 were lit. any suggestions?
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • SS454
                            vizio e650i-a2 backlight flashes then turns off
                            by SS454
                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                            panel: au optronics T650HVN05.4
                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                            08-20-2020, 03:57 PM
                          • mrtek
                            Vizio M65-C1
                            by mrtek
                            Hi.
                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                            07-14-2025, 07:28 PM
                          • howardc64
                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                            by howardc64
                            Failure Symptom
                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                            Where is the short?
                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                            05-27-2025, 02:56 PM
                          • howardc64
                            Vizio SmartCast TV software bug that looks like hardware
                            by howardc64
                            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                            11-16-2024, 05:17 PM
