Vizio vp422hdtv10a no audio,no video.
  • Peter B
    • Nov 2012
    • 28
    • erie
    2 relay clicks when a/c cord plugged in,Vizio logo on front panel stays amber/orange.visual inspection ok caps appear ok fuses good,have stand-by voltage of 5.3vDC. PSON is .489vDC,ac detect 5.15vDC,read in a thead that u can apply voltage to PSON(3.0vDC)to turn on power supply.no new voltages ,except 2 sub fuses on power board volts rose from 25vAC to 60vAC.
    an the relay clicked on,relay got warm an couple small caps did also.Disconnected all other boards,no effect.help
    Re: Vizio vp422hdtv10a no audio,no video.
    Test according to this video:
    https://www.youtube.com/watch?v=cNFzBJELFoU&t=2m50s
    (It's a different fault, but Vizio have lots of problems with voltage regulators causing lots of problems.)
    • Peter B
      • Nov 2012
      • 28
      • erie
      Thank u for resonding so quickly.i have reveiwed the info that u had sent,did watch that u tube vidieo before. it was similar but that set @ least turned on.
      my set dosent turn on @ all. so some of the readings were simalar, or none @ all.Reveiwed the flow chart,some findings lead me to power supply.Before i did anything to the set found w3 micom board on power suooly was flashing twice, power supply legend states that D5v/vg/12V m.i.a.now is steady with
      still no voltages.Ugh!!!!!think power suply issues.
      • Peter B
        • Nov 2012
        • 28
        • erie
        on my tv U 33 has 8 leggs an not 3. How do u ckeck for power saving mode? Did flow chart testing for monitor display nothing (pc mode).
        #1 power board output +5VSB,F4? 5.3VSB F4 5.1V
        #2 J1 connector of MB good? yes
        #3 Is DC/DC ok?
        i skipped #3 ckecked #4 real quick ck U 22 Pin#2 3.0V yes 3.0V
        Now # 3 DC-DC ok? went to DC/DC converter flow chart,
        #1 voltage is about 5V(5VSB) yes 5.3V
        #2 check power board,yep,its still there,
        #3 check power cable,F4ok? yes and yes
        #4 j1 connection ok? yes
        #5 check U 22 pin3 5VSB? yes 5.1V
        ckeck pin #2 3.3V? yes 3.3V
        • Peter B
          • Nov 2012
          • 28
          • erie
          H e l p...
            This is a different main board. U33 isn't a regulator on this one.
            Can you test all the others?
            • Peter B
              • Nov 2012
              • 28
              • erie
              Main board P/N# 0171-2272-2585
              V50P FHDTV10a
              U-4 pin #1 0.0
              #2 0.0
              #3 10.4mVdc
              U-15 pin #1 35.7mVdc
              #2 57.3mVdc
              #3 10.5mVdc
              U-16 pin #1 1.0mVdc
              #2 0.0
              #3 0.0
              U-17 pin #1 0.0
              #2 0.0
              #3 10.5mVdc
              U-18 pin #! 0.0
              #2 0.0
              #3 0.0
              U-19 pin #1 0.0
              #2 0.0
              #3 10.5mVdc
              U-20 pin #1 0.0
              #2 0.0
              #3 57.4mVdc
              U-21 pin #1 0.0
              #2 .7mVdc
              #3 0.0
              U-22 pin #1 2.0Vdc
              #2 3.3Vdc
              #3 5.15Vdc
                The only regulator in use in standby is U22, and it is working fine. (ADJ is 1.25V(±0.05V) less than OUT.)
                I see at least three fuses on the main board, white ceramic coloured, gold or silver capped, near the power connectors. With the set unplugged test the resistance across them. On a DMM you should see less than 2 ohms.
                Then plug the set in and check the voltage either side. If there is a supply, such as 12V, on one side, but not on the other, then there is a problem with that fuse.
                • Peter B
                  • Nov 2012
                  • 28
                  • erie
                  There are 4 fuses, F1,F2,F4 are ceramic.
                  F1-.736Vdc
                  F2-1.9mVdc
                  F3-5.15Vdc
                  all r good.
                    What does VDC indicate in this instance? Also, where is the fourth fuse?
                    • Peter B
                      • Nov 2012
                      • 28
                      • erie
                      Im assuming its a fuse,labled on min board as F3. 11.4mVdc, has a single white "G" on it.
                        Please, what does "11.2mVdc" mean? Across it? From each end to chassis? Can you test them on the ohms range too?
                        • Peter B
                          • Nov 2012
                          • 28
                          • erie
                          11.2mVdc,i thought meant milli volt,so,11.2milli volts dc. the first readings were with a/c cord plugged in chassis ground,unplugged all fuses read 000.1omhs.
                            I understood mVdc. But I'm confused about which end you were testing. Were both ends the same? Any time there is a significant difference, the fuse is open (failed.)
                            • Peter B
                              • Nov 2012
                              • 28
                              • erie
                              its NOT a fuse. missing 5v and 12v.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                I still dont follow this I dont know how Tom saw the fuses on the board this is the worst set of pictures I have seen for some time.
                                Where is the 4th fuse if it is labelled F3 where is the one labelled F4.
                                We should have pictures where we can see the board labels next to the component
                                like in these
                                https://www.badcaps.net/forum/attach...1&d=1290283049
                                https://www.badcaps.net/forum/attach...7&d=1280167246
                                  I am completely lost. As Selldoor said, we need better pics. That is all we have to work from.
                                  You need to follow this test exactly...
                                  For each F1, F2, F3, F4:
                                  - Measure the voltage on one end.
                                  - Measure the voltage on the other end.
                                  - Report the readings.
                                  If there is a significant difference between the two, suspect the fuse.
                                  • Peter B
                                    • Nov 2012
                                    • 28
                                    • erie
                                    i have enclosed a picture off the web of ALMOST the same @ shop jimmy,cant get a good picture of mine.(mine m/b also has a reset button,which is not pictured)....ok fuses,
                                    with a/c cord plugged in,ground to chassis F1-.736VDC both sides,
                                    F2-0.0VDC,both sides, F3-0.0VDC,both sides,F4-5.16VDC,both sides.
                                    Also, ckecked both sides sides,of fuses with a/c cord unplugged,meter
                                    set @ omhs with tone all ckeck ok.
                                      OK, all fuses are good.
                                      Is there a pin marked PS-ON on the power supply? What does it report when the TV is in standby and when the power button is pressed?
                                      • Peter B
                                        • Nov 2012
                                        • 28
                                        • erie
                                        tv set doesnt turn on,in stand-by, PSON reads .497VDC,
                                        pressing power button changes nothing.
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                          GeForce RTX2080 Super Aero video gaming card issues help need
                                          by sam_sam_sam
                                          This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                          Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                          05-07-2023, 08:12 AM
                                        • ajshoe
                                          vizio E60-E3 backlights, sound, no video
                                          by ajshoe
                                          Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
                                          Does this mean remove right side (from front of TV) tabs ?
                                          Like a second opinion before possibly destroying set....
                                          04-07-2023, 01:59 PM
                                          HP ProBook 450 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 450 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-06-2024, 06:20 AM
