Supervisor password on Lenovo T490 and T490s
  • Pasha_Lu
    • May 2020
    • 11
    • Ukraine
    #41
    Re: Supervisor password on Lenovo T490 and T490s
    Thank you.
    • izaak94
      • Mar 2019
      • 132
      • mexico
      #42
      hello can someone help me to read MEC with SVOD3? I need to unlock a T490s
      • jogas
        • Oct 2019
        • 17
        • IE
        #43
        ineed this help aswell.please any one
        • couillu76
          • Jan 2022
          • 39
          • United Kingdom
          #44
          Hi i have been trying to unlock with svod4 for weeks unfortunatly i have failed because svod can only read 288kb so decide to buy a rt809h this one read the full ec 290kb or more and it work at the first attempt
          • pehol193
            • Oct 2019
            • 8
            • Poland
            #45
            what you did with dump, to unlock password?
            • couillu76
              • Jan 2022
              • 39
              • United Kingdom
              #46
              i have read the 290kb save it and rewrite it to the ec , i have done x1 gen4, x13, t14 t490 in same way , after that i used the lenovo tool to rewrite the motherboard infos
              easy when you know
              • mika123
                • Jun 2020
                • 4
                • india
                #47
                Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
                Nm-b901, t490 need patch file I7-8TH GEN CPU
                • mgjini
                  • Sep 2017
                  • 199
                  • united kingdom
                  #48
                  can anyone remove the password from this mec1663 lenovo t490 please nm-b901
                  • rex98
                    • Feb 2023
                    • 1287
                    • Mandaue CEBU, Philippines
                    #49
                    what programmer did you use to read mec1663?
                    • AAAC
                      • Jan 2020
                      • 458
                      • Mexico
                      #50
                      @mgjini
                      In my experience, when you erase the EC chip to reprogram it, is when the internal EEPROM contents are erased too, that EEPROM memory hold the Supervisor Password among other data like Model Number, Serial Number, TYPE, etc.
                      So depending on the programmer you are using the next step is to reprogram the EC chip with the exact file you saved from EC, then use the software utility (ThinkPad Maintenance Utility) that is in another post to program the ThinkPad DMI information.
                      I've verified the EC file you uploaded, version N2IHT39W, with the corresponding BIOS/EC update downloaded from Lenovo and it is an exact copy; I just had to delete the header from the EC update (first 32-bytes) and the tail starting from 40000h all the way to the end, then I could do the comparison of both files.
                      • mgjini
                        • Sep 2017
                        • 199
                        • united kingdom
                        #51
                        So the story of programmer is I bought from eBay 2 years ago from eBay from some guy io programmer and when arrived I see the software doesn't work so after researching I had to get in touch with verytanov and paid for his software 50$ so I used verytanov and then jtag one user here has done great job providing the picture
                        • mgjini
                          • Sep 2017
                          • 199
                          • united kingdom
                          #52
                          Originally posted by AAAC
                          @mgjini
                          Unfortunately I am not quite advanced to edit files so I have to research how to get this done
                          • AAAC
                            • Jan 2020
                            • 458
                            • Mexico
                            #53
                            @mgjini
                            You don't have to edit anything, the programmer is properly connected as you could read the EC, the next step would be to reprogram the EC with the same file on post #48 (the reprogramming should take care of the EEPROM contents when the chip is erased prior to programming). After a successful programming then remove all source of energy, reconnect and that should have take care of the Supervisor Password, then you just need to use the Lenovo Maintenance Utility to type the DMI information.
                            • mgjini
                              • Sep 2017
                              • 199
                              • united kingdom
                              #54
                              @mgjini
                              Hi thank you for your advise I will try that in my future laptops as I have some x390 also and want to test on that, thank you very much I resolved this some
                              Guy edited for me and I dint have to use dmi, mine is resolved thank you guys
                              • HAWKAR
                                • Sep 2022
                                • 6
                                • iraq
                                #55
                                hello
                                how i can use my r809h for t490 to read the ec? how i can connect it with this board?
                                • rex98
                                  • Feb 2023
                                  • 1287
                                  #56
                                  LENOVO THINKPAD
                                  T490 T590 FT490 FT492 FT590 FP531 NM-B901 REV 1
                                  this main supports all the models above and the MEC is also unlocked.
                                  • binhraucomputer
                                    • Jun 2022
                                    • 2
                                    • việt nam
                                    #57
                                    I have a lenovo laptop with bios password stuck. Can anyone who has done it tell me how to wire the jtag and am using a rt809h reader?
                                    • jozlar
                                      • Mar 2022
                                      • 59
                                      • tbilisi
                                      #58
                                      Originally posted by hoaca388
                                      Re: lenovo thinkpad t490 bios password
                                      Here
                                      please help t490s nm-b891 unlock please patching help me
                                    • jozlar
                                      • Mar 2022
                                      • 59
                                      • tbilisi
                                      #59
                                      please help mec unnlock
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1258
                                      • France
                                      #60
                                      need serial number, read rules
                                      clear 300 to 33F
                                      • AppleLover123
                                        Lenovo Yoga X380 22LH Supervisor Password removal
                                        by AppleLover123
                                        Hey guys,
                                        have a laptop here that has a supervisor Password (dump in Attachements).
                                        Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                        the laptop works but everytime it wants me to type a supervisor password i never set.
                                        I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                        Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                        04-17-2025, 03:42 PM
                                      • baaligoga
                                        Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                        by baaligoga
                                        Good day, everyone!
                                        I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                        I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                        05-20-2023, 09:48 AM
                                      • Andreasandreou
                                        Lenovo Thinkpad T14s GEN 4 Supervisor Password Bypass
                                        by Andreasandreou
                                        Hello, I have Lenovo Thinkpad T14s GEN 4 serial number GM-0FK2ER laptop. It was brought to me by a customer to reinstall windows. The problem is it is locked with a superviser password. Can anyone please give instructions on how to reset the bios or bypass the supervisor password? Thank you.
                                        09-02-2025, 09:45 AM
                                      • Pusher
                                        Lenovo P16 Gen1 Supervisor Password from factory
                                        by Pusher
                                        Hi, I bought a Lenovo P16 Gen1 from a private seller. The box was still originally sealed but when I want to enter the BIOS a supervisor password is required. Is it possible that the notebook was delivered by Lenovo with a password? What can I do to reset the password? Unfortunately, I no longer have contact with the seller.
                                        11-08-2023, 12:14 PM
                                      • lrservicios
                                        Lenovo Thinkpad X12 Detachable 1st GEN Supervisor Password
                                        by lrservicios
                                        Hi !
                                        I have a Lenovo Thinkpad X12 Detachable 1st GEN with Supervisor Password - Type 20UV-S2Q100 Serial Number: PW-01NB9P - PW01NB9P
                                        I attach Bios 2 Chip reading Bin, please can you try to clear it for me ?...
                                        05-02-2025, 12:35 PM
