Need HP EVP51 LA-G078P Schematic
  • Tinfomais
    • Dec 2019
    • 20
    • Portugal
    Hi, I have a faulty motherboard that turns on for 5 seconds and then turns off, I've tried flashing BIOS and EC without any change to behavior, I need the schematic to test voltages to see if there's one missing or out of spec and other things.
    Laptop model HP 15-db0060ns.
    Thanks in advance.
  • anshad
    • Nov 2010
    • 249
    Re: Need HP EVP51 LA-G078P Schematic
    It's currently unavailable. Nowadays HP schematics rarely leaks to the net.
    • Nilam
      • Mar 2021
      • 18
      • Nepal
      EPV51 LA-G078P schematic or compatible schematic
      Dear sirs
      Kindly help for the above.
      Nilam
      • bokarnold28
        • Jan 2021
        • 10
        • philipines
        unavailable until now?
        • chamel
          • May 2022
          • 1
          • Sri lanka
          EVP51 LA-G078P Schematic plce help
          • Rezistor
            • Jun 2021
            • 288
            • USSR
            The archive is password-protected, the password is unknown to me, maybe someone will crack and lay out the LA-G078P scheme
            • mberbouch
              • May 2014
              • 108
              • Morocco
              Thanks for the post
              • kuldeepvitoni
                • May 2023
                • 1
                • india
                Please give me password
                  • 21184
                  • VUONG MAI
                    • Dec 2022
                    • 15
                    • Viet Nam
                    For anyone in need
                    • M4n0l0307
                      • Nov 2020
                      • 167
                      • Colombia
                      Originally posted by VUONG MAI
                      For anyone in need
                      Thanks Friend !
                      • mohammedsaid
                        • Feb 2016
                        • 68
                        • egypt
                        Need Schematic please
                        • mohammedsaid
                          • Feb 2016
                          • 68
                          • egypt
                          Need Schematic please​
                          • ivanwx2000
                            Ivanwx2000
                            • Oct 2019
                            • 7
                            • Colombia
                            deberian dejar de estar subiendo lo q no sirve para que sirve un archivo encriptado
                              • 21184
                              What does that mean in English..
                              • Stephen
                                MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                by Stephen
                                MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                03-15-2024, 09:37 AM
                              • toty79
                                Lenovo B50-50 (80S2) No display no Post
                                by toty79
                                Hello friends and welcome back,sorry for my English but I'm in Italy and I'm using a google to translate
                                Main board CG410/CG510 NM-A681 rev 1.0
                                I have this Lenovo laptop under repair with strange behavior, no display at first I thought it has a corrupt bios but now after disassembling it I have doubts, the laptop turns on automatically after inserting the charger without pressing the power button, If I hold down the power button for 8 seconds, it turns off for 1 second but turns on immediately after 1 second, so you can't even turn it off, tested with and without RAM,...
                                02-17-2024, 03:11 PM
                              • www
                                LG L192WS-BN backlight turns off after 1 second
                                by www
                                I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                03-24-2024, 05:26 PM
                              • TinkerTron
                                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                by TinkerTron
                                Hey everyone,
                                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                Instead, here's what's been bugging me so far:
                                The schematic...
                                03-06-2025, 02:03 PM
                              • atunguyd
                                Acer x163w Monitor PSU schematic
                                by atunguyd
                                Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                03-05-2025, 02:08 PM
