Dell e173FPF Caps?
  • lcdman
    TinkerTech
    • Nov 2010
    • 232
    • U.S.A.
    Dell e173FPF Caps?
    Hello All,
    I recently acquired a Dell e173FPf. Board number 790271200800 (4 lamp connections). It appears that someone hacked they're way into it and then did a half-ass repair! I've seen other posts about this monitor and board but no really good photos of this board. Does anyone out there have one of these boards and can tell me ALL the cap numbers with there proper uf and voltage? It would be awesome if ya do. That way I could double check and see if the right caps are in there correct place and values.
    Thanks Again,
    lcdman
  • Rtech
    • Jul 2010
    • 1095
    Re: Dell e173FPF Caps?
    Originally posted by lcdman
    Hello All,
    Thanks Again,
    lcdman
    I assume you mean the electrolytics only??,so here goes...
    C6..220uF..25v
    C26and C859..as above
    C4 and C25..47uF..16v
    C857...10uF...50v
    C864 and C869...470uF..25v
    C862...1000uF..25v
    C871..680uF..16v
    All the other small caps except C506...47uF..16v
    C506...4.7uF...16v
    hope that helps
    • lcdman
      TinkerTech
      • Nov 2010
      • 232
      • U.S.A.
      Hello Mr. Rtech,
      Thanks for your help once again! Your list revealed some errors that the previous HACK had made. Just have to test the SMD transistors now. You wouldn't happen to have a list of all of them and there values? If not maybe one of the other fellas on this site might. My 2.4mm X 348mm CCFLs came today so maybe I can get some of the other "e" 17" Dells up and running finally.
      Happy New Year To All,
      lcdman
      • jassink
        • Jan 2011
        • 3
        C6..220uF..25v
        C857...10uF...50v
        C862...1000uF..25v
        C871..680uF..16v
        C506...4.7uF...16v
        hope that helps
        I am jumping into this post with a problem. My monitor died, no backlight but you can still see the image on the screen and I have the exact same board and looking at my caps C869 is 470uf but not 25v, it is 16v. Could this be the source of my problem?
        • retiredcaps
          • Apr 2010
          • 9271
          Please post a clear focused picture of your board using the manage attachments feature. Do not post inline.
          It is not uncommon for manufacturers to make revisions on the board and keep the same model number.
          Last edited by retiredcaps; 02-03-2011, 04:11 PM. Reason: edit: comments re wrong monitor
          --- begin sig file ---
          --- end sig file ---
          • Ritalin
            • Sep 2010
            • 194
            It shouldn't be, the voltage on the capacitors is close enough where it shouldn't make a difference. With that being said, the capacitor still could be bad. Check to see if it's bulging at all.
            • jassink
              • Jan 2011
              • 3
              Here are the pics
              • jassink
                • Jan 2011
                • 3
                FIXED!!!
                I replaced the caps at C6 and C26 and now it works...they didn't look bad but found info in another post.
                Thanks!
                • Ritalin
                  • Sep 2010
                  • 194
                  Congrats on your fix! That's the tricky thing with capacitors, even though they look fine, they could be dry inside. That's why I'm tempted to save up and get one of those meters where you can check them while they're still intacted on the board.
                  • el3ctroded
                    • Nov 2008
                    • 198
                    Thanks jassink, that post helped me fix one!
                    • atriverfaith
                      • Sep 2012
                      • 2
                      • US
                      Just wanted to add that I fixed one of these displays by reseating the MPU chip in it's socket. The chip can be pushed down too far. There is a plastic spacer in the bottom of the socket to prevent this but it may be too thin. Hope this helps someone.
                      • Gish228800
                        • Jun 2016
                        • 1
                        • Kenya
                        My Dell e173FPf with a similar problem, the capacitors looks just fine, is there a way i can determine if they are dry inside?
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                          by momaka
                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                          https://www.badcaps.net/filedata/fetch?id=3591771
                          https://www.badcaps.net/filedata/fetch?id=3591772
                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                          https://www.badcaps.net/filedata/fetch?id=359177...
                          03-12-2025, 03:42 PM
                        • huzo
                          DELL Latitude 3500 no image, fan max speed, caps lock frozen
                          by huzo
                          Dell latitude 3500
                          Board BOLT-L UMA MB
                          17938-1
                          FW8G6$LA
                          when i press the power, fan goes full speed, power button lights up , and caps lock light is on, the screen polarises, goes dark,no backlight...All voltages present, except PL4701, but that's probably for GPU power later....
                          I've tried a few dumps from posts, it always acts the same, so i thin it's not a bios issue...
                          No shorts found on the board...
                          What should i try next?
                          10-06-2024, 02:15 AM
                        • Akhlz001
                          Dell Pro 13 Plus PB13250 Bios Unlock
                          by Akhlz001
                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                          09-20-2025, 07:15 PM
                        • eryjus
                          Heathkit IO-4205 Power Supply Caps
                          by eryjus
                          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                          05-10-2023, 11:21 AM
