chromebook enrollment, not done by RCunlocker
  • tarek5313
    • Mar 2015
    • 31
    • United Kingdom
    RCunlocker is very good tool but technology change over time and this tool is not updated for long time now
    ok here is why and the solution
    the why?
    g00gle have changed how the machine ID is generated now so they can assign MDM policy to machine, its not S/N anymoe rather the "stable_device_secret"
    the solution:
    very simple, just to provoke that ID, usually i just flip the last two bytes of that ID, maybe someting else will do the trick? in theroy YES, but this is what works for me
    HOW TO:
    just fire any hex editor and find "stable_device_secret_DO_NOT_SHARE@"
    you will find a 65 character ID
    now flip the last two bytes of that ID
    NOTE:
    you still have to use RCunlocker if you want developer mode ON, so yes you have to apply both modification, doesn't matter which first
    last step is to wipe the machine before it connect to internet
    this is easy, on first boot up (Esc + Refresh + Power) then (Ctrl + d) it will fail, no problem, the goal is to wipe it
    good luck
  • Dusan2504
    • Jan 2023
    • 13
    • Serbia
    Re: chromebook enrollment, not done by RCunlocker
    the why?
    the solution:
    HOW TO:
    NOTE:
    good luck
    I am here to confirm that this solution is 100% successful
    • Danitan210789
      • Feb 2023
      • 8
      • Mexico
      thnx for respond, but i try this solution and the device relock.
      this lock is only wifi o internet conection.
      • Dusan2504
        • Jan 2023
        • 13
        • Serbia
        you have to run the file through rc unlocker and change these two bytes
        • tracker1
          • Jul 2017
          • 122
          • romania
          100% working!!! THANK YOU !!!
          • b4rdock
            • Jun 2017
            • 108
            • usa
            this not work for new like this can unlock it plz ? HP Elite Dragonfly 13.5"
            sku_number 6M5X6UC-ACH
            serial_number
            5CD303487P​​
            • peste
              • Dec 2016
              • 14052
              • ROMANIA
              serial_number
              5CD303487P​
              try...
                • 22424
                serial_number
                5CD303487P​
                Your backup is 32,640KB it should be 32,768KB .Maybe something wrong with your programmer or the chip.
