Samsung UN60J620 Backlight or PS?
  • jason123
    • Oct 2015
    • 1069
    Hi Folks,
    Troubleshooting a TV that doesn't have backlight (Flashlight tests ok - I am getting data on screen - no backlight)
    I see Firmware ICs and PS repair kits on eBay in addition to the obvious bad Backlight.
    I'd hate to open up the panel to find a different problem though.
    So here are some measurements I was hoping someone can tell if it's backlight or something else.
    Main board is getting 13V standby and does generate the 3.3 PWR_ON signal
    On the Power supply board:
    D+, D- = 417 V
    S+, S- = 402 V
    (guessing if D+ and D- are same voltage then there is no current flow = translate to open LEDs?)
    Readings above are when TV is on, and referenced to COM (Chassis)
    I tested the problematic Diode - it has 417 V across it. Upon removal, it has 0.7k ohm, and 3.9 k ohm (keeps going up)
    Any other measurements to take to confirm the diagnosis?
    When I apply voltage from D+ to S-, and S+ to D- I get some LEDs lighting up. I don't have the panel open, so I don't know how many if any are dead LEDs.
    Thank you
    Thank you all
    Re: Samsung UN60J620 Backlight or PS?
    Which Diode? What is the designator for that Diode, Dxxxx?
    It is bad if it shows resistance in both directions.
    Board: BN44-00775A
    • jason123
      • Oct 2015
      • 1069
      D9001C... from other posts you've helped on, the same resistance was the issue. You think it's bad with these readings?
      Yes, this is the BN44-00775A
      • neilc6
        • Nov 2015
        • 1550
        If you want to fix TVs, you need to invest in a LED tester. 80% of TVs I repair have bad LEDs and I use my LED tester more than my multimeter. Pay a bit more for one that is higher current.
        • jason123
          • Oct 2015
          • 1069
          I have a home rigged 380 V with adjustable current from 3 to 25 mA. I have used it for years.. bulky and ugly but it does the job.. i think
            " it has 0.7k ohm, and 3.9 k ohm (keeps going up)"
            Replace it.
            See the LED driver topology, if the diode is leaky you will get same Voltage reading on D+ and D-.
            Also check SMD resistors R9032/9033 right by the LED connector.
            • neilc6
              • Nov 2015
              • 1550
              A LED tester will read back the voltage across the probes so you can tell right away if you have an open or lots of shorted LEDs without opening up the panel. I have also used the tester to power up the backlights independent of the power supply to confirm a tv has video and the screen is good before ordering new strips.
              To test a diode, unsolder and lift up one leg and put your multimeter in diode test mode. It will read a voltage drop forward biased and open reverse biased. If shorted, it will read 0V both directions.
              • jason123
                • Oct 2015
                • 1069
                Thank you.. might invest in a tester.. any specific brand or kind?
                • jason123
                  • Oct 2015
                  • 1069
                  Thanks budm... great help as always.. yes Diode is bad. Replaced and backlight is back on.
                  • neilc6
                    • Nov 2015
                    • 1550
                    Something like this does 300mA but looks like euro plug. https://ebay.us/2MDAX3 May be cheaper on Aliexpress.
                    I would play a blank white test video or display a plain white jpeg and look for dark patches to see if you have shorted LEDs.
                      Great, make sure to set the Backlights level on all input to as low as possible to extend the life of the LED's.
                      Do the white screen test as suggested too.
                      • jason123
                        • Oct 2015
                        • 1069
                        Will do.. thank you budm and neilc6
                          BTW, you can use the LED tester to test Zener diode, and diode (rated >300 Volt) too.
                          • jason123
                            • Oct 2015
                            • 1069
                            I'll have to circle back once i get it. Excited to get it now. Thank you
                            • zape
                              • Jul 2017
                              • 176
                              Replace it.
                              Just checking it to say thanks to budm
                              D9001C was faulty in my case too.
                              replaced it with some random high voltage diode and the TV is workin!
                              • zape
                                • Jul 2017
                                • 176
                                in my case it was both the D9001 diod and the LEDs, almost half of the leds were dead
                                  09-07-2024, 05:50 AM
                                • howardc64
                                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                  by howardc64
                                  • Prior owner tried a replacement main board. No difference.
                                  • Samsung 2x red blinking standby LED = panel fault
                                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                  07-19-2025, 10:54 PM
                                • Warrensmith
                                  Samsung BN44-00807E Low Backlight
                                  by Warrensmith
                                  Symptom is dim backlight - this set came in with almost no backlight.
                                  Samsung UN55JU6500FX2A
                                  1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
                                  2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
                                  Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
                                  10-27-2022, 07:09 AM
                                  09-06-2024, 11:40 PM
