Lg 42pc3d
  • drpj23
    • May 2012
    • 528
    Lg 42pc3d
    Ok, so I have the sound no picture issue with this tv.
    I plugged it in, let it sit on, and felt the sustain boards and the Z was cold compared to the Y. So I replace that. Same issue.
    Well on each board there was a bad fuse (you'll see in the pictures the ones missing which were the ones that were bad)....unless these are bad or not there, then the power supply clicks off. In order to get the previous issue (sound but no pic) there must not be a fuse in both or both sustain boards be disconnected from P/S.
    All voltages are right from P/S.
    Any thoughts?
  • TechShui
    • Jun 2011
    • 148
    Re: Lg 42pc3d
    A blown IPM in either sustain board will cause your power supply to go into protection mode.
    If the new Z-sus is actually functioning properly, then you should be able to disconnect the Y, leave the Z-sus (with fuse) plugged and get the TV to turn on, with no video.
    Right now it sounds like both boards are dead, but lets hope not.
    • drpj23
      • May 2012
      • 528
      Re: Lg 42pc3d
      doesn't matter which is disconnected from the P/S, it still goes into protection mode but if I remove the fuse for the Vs (186v) side (for both boards) it powers on to the sound but no pic issue.
      The old Z sustain would let it power up with 2 good fuses, but the heat sink was cold compared to the Y sustain.
      Also, the continuity on each terminal for the fuse holder on the Y sustain for Vs side gives off a reading that goes up then eventually down to 0 and beeps as if you were testing a diode.
      • TechShui
        • Jun 2011
        • 148
        Re: Lg 42pc3d
        Did you figure it out yet?
        There's a good test guide here for the IPM
        http://blog.coppelltvrepair.com/2011...s-ipm-for.html
        • drpj23
          • May 2012
          • 528
          Re: Lg 42pc3d
          Sadly not, I just parted out the TV and held the parts to the side but thanks for the link, at least I can mark the bad ones.
          Overall, I believe both sustain boards went out, though odd that happened.
          I decided to part it since the parts would most likely meet the price of the TV and there wasn't a 100% to that fix. But, shall another come in, I have some parts to mess with (or at least I'll have possibly good buffer boards and a controller board)
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            Hi everyone,
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            Diagnosis showed PP1V5_UPC0_LDO_CORE shorted to ground.
            I replaced U3100 (UF400) using a donor board (A2179), and the machine powers on fine now.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
          • shahnld
            Lenovo legion 5 pro startup issue
            by shahnld
            Good day Experts
            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
            08-24-2025, 12:31 PM
