Techwood 32884 HD Digital
  • comptek
    • Aug 2013
    • 606
    • uk
    Hi i am having a problem with a Techwood 32884 HD Digital lcd tv
    the problem is that the blue and orange LEDs are flashing, if you keep pressing power on remote it comes on and works as it should side buttons do the same
    power supply is a VESTEL 17pw25-3 and mainboard is a VESTEL 17mb60-2
    i have done a factory reset MENU 4725 and still the same so im at the point where it needs the firmware updating or its corrupt?
    the number on the white label is 10070358
    the version at the moment is V.06.2.D dated 2010-09-08
    the screen is LG
    the tuner is Samsung
    can someone supply the needed firmware
    any help would be great
    many thanks
    Gary
  • comptek
    • Aug 2013
    • 606
    • uk
    Re: Techwood 32884 HD Digital
    any idea where to get the firmware from please
    regards Gary
      If the set boots up and run:
      Enter MENU 4725
      Plug in USB stick which is **COMPLETELY BLANK** and formatted FAT32
      Select "NVRAM download" or similar
      This will copy the firmware from the TV to the USB
      Verify the files on a computer look good (should be mboot.bin, and others)
      Then install the firmware using the normal method.
      • comptek
        • Aug 2013
        • 606
        • uk
        thanks Tom66 i will give that a try when weve moved
        thank you for your help
        • comptek
          • Aug 2013
          • 606
          • uk
          Enter MENU 4725
          hi Tom66 i have now got round to try the above idea.... but there is no option to do anything like it i have tried all available setting tabs
          any other ideas anyone please
          • Bazilwrc164
            Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
            by Bazilwrc164
            I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
            The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
            I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
            If anyone can provide:
            • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
            • Or a compatible EEPROM dump
            07-23-2025, 12:15 PM
          • massimomax
            Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
            by massimomax
            Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
            spero che qualcuno può averlo per riprogrammare eprom. grazie
            Post in English !!!
            I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
            02-28-2025, 07:27 AM
          • lberkani
            Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
            by lberkani
            Hi everyone,
            I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
            The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
            The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
            I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
            - Toshiba 65UL2163DG
            - Vestel 17MB180E mainboard
            - Panel VES650QNTX-N2-N42
            - Version V1.28.100.0 if available
            If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
            11-11-2025, 12:37 PM
          • anlu
            Vestel Firmware - Toshiba 32W133DN
            by anlu
            Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
            Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
            02-04-2023, 12:59 AM
          • piernov
            Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
            by piernov
            Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
            I suspect corrupt firmware but I haven't been able to find anything for this TV.
            TV model: Finlux 65-FUC-8060
            Mainboard: Vestel 17MB130S 23473048
            Panel: VES650QNTS-2D-U11
            At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
            06-01-2024, 12:57 PM
