Re: Sony XBR-65X810C Not Powering on
Thank you freakaftr8 and nomotesonys for the guidance thus far, Got around to trying to get the backlights on. I tried dc_dimmer and pwn_dimmer separately with bl_on all to 3.3v standby with no luck. I also tried all 3 together and nothing happened. I did want to report that at connector cn6801, on the pin +out1 I get 92v and no other voltage on any other pin. (Under regular plug in conditions) This connector looks to goto the backlights. When I had the jumpers connected I did not see the voltage. Anyone know if this power supply can force the backlights on for testing? Any other troubleshooting to confirm the issue is mainboard? I find it odd that I’m not getting any error codes from the indicator. Thanks!
