ASUS K52Jc No Power
    ASUS K52Jc No Power
    Hi Everyone! i have a problem with Asus K52J, it has no power but sometimes when i plugged in the chareger it becomes auto power on. Can i ask what must be the main cause? and i hope anyone can give me a schematic diagram :-) main board label is K52JC rev 2.0
    i hope someone could notice my post.. TIA
    Re: ASUS K52Jc No Power
    https://cdn.badcaps-static.com/pdfs/...3a9e7f98b3.pdf
    or
    https://www.badcaps.net/forum/showthread.php?t=36264
      Hi Sir! i think ASUS K52JC is different from the link that u gave :-) i hope you can help me sir thanks a lot
        Finally I noticed your post sir This is the board view, it might help you.
        sigpic
          thanks for this one sir, but unfortunately i cant open the file? can i ask for pdf file sir if u dont mind :-) thanks for the help... really appeciate it
            Software to open those file:
            https://www.badcaps.net/forum/showthread.php?t=56151
            http://boardviewer.net/index
            Schematic, not available
              tnx for the info sir
                Do you solve your problem?if not ,check 19v on the fuse after the two beginning MOSFET ,if is present then check 3 v and 5v (always),if it isn't ,then check your charger ic (vin,acin,acok),sometimes there is a bad connexion on charger ic disoldering and soldering it again may solve problem ,(but not always) you should check 19 v on the fuse after the two switch if isn't present check acin (3,3v) a divider with two resistance if you don't have acin 3,3v the charger ic will not switch the second transistor to get 19 v on the fuse or resistance ( generally it called B+) also check the two first transistor if one of them defected and make sure B+ not shorted.
                Sorry for my bad English ,
                Hope that help you sir
                  thanks
                    I landed at this thread because my ASUS K52Jc suddenly began displaying a flashing orange LED near the touch pad instead of the normal steady green LED in that position. I performed all of the software related fixes that I could find on the net. The next indication was either a bad battery or a bad motherboard. At this point, since the symptoms were the same as no battery present, I took the step of removing the battery and at the rear of the computer I applied slight outward force to each of the two large blades related to the battery + and -. I reinserted the battery and the problem is resolved. Contact cleaner might have accomplished the same. So, I didn't need to replace any caps but I'm happy to have discovered this site dedicated to cap replacement. A very useful reference. Thank you one and all.
                      thanks a lot
                        thanks
