Long story short, I pulled a working SSD out of a system (upgraded it to a larger one) and connected the old pull to another controller. Ever since, the drive is no longer accessible, even in the system it originally came from. BIOS's see it, but it can not be initialized, read, partitioned, etc. I've tried a couple utilities on it, which see the drive....but some say 'lost partition', and timeout attempting to recover it. I can care less about the data on it, I dumped it before I started diddling with it.....but is there any way to recover/reuse the drive itself? It was perfectly fine before..... It's a 240gb OCZ TRION150.
Weird SSD Issue
Weird SSD Issue
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsTags: None
Re: Weird SSD Issue
If it was ESD, that'd be a first in all my years...but I suppose it's possible. DBAN seems to be communicating with it....so I'll let DBAN zap it and see if it comes back to life.....last ditch effort before it ends up in the trash.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team Stats
Re: Weird SSD Issue
^ Ive had SMART erases bring SSDs back to life. Last ditch effort if DBAN failsThings I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.
Re: Weird SSD Issue
Originally posted by goontron View Post^ Ive had SMART erases bring SSDs back to life. Last ditch effort if DBAN failsASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
Re: Weird SSD Issue
Originally posted by Topcat View PostIf it was ESD, that'd be a first in all my years...but I suppose it's possible. DBAN seems to be communicating with it....so I'll let DBAN zap it and see if it comes back to life.....last ditch effort before it ends up in the trash.sigpic
(Insert witty quote here)
Re: Weird SSD Issue
Originally posted by ratdude747 View PostIf you toss it, can I have a crack? I'll pay shipping...<--- Badcaps.net Founder
Team : 49813
Join in!!
Team Stats
Re: Weird SSD Issue
I've had some strange issues caused by dirty SATA plugs and contacts on drives, both mechanical and a brand new SSD. The SSD in question is actually running perfectly in the E6400 I'm posting from. After imaging the original HDD to the SSD, this laptop didn't even see the SSD when placed into the internal bay. Yet it worked fine in the ext enclosure...
Spray the SATA cable plugs with Deoxit or your favorite substitute. Also scrub the SATA connector, both power and signal, with a Deoxit-dampened swab.
A few months ago, the HDDs (it would've seemed) in my main PC got slow. Sometimes holding the IRQs, just as a bad drive would in the old days. Re-enabling UDMA would always revert back to PIO, after any attempts to copy. I pulled the drives and cleaned the HDA-PCB contacts, and connected them to another system & backed them up. Great speeds now...
But in the main system, back to slow-ville. An 8 hour+ ETA for what should've been an hour's worth of copying. Tried several combinations of drive/SATA cable, finally discovering one which was suspect. Sprayed the ends of all 3 with 2-26 and cleaned the SATA contacts.
That did it. We were off, to the moon, Alice!Last edited by kaboom; 12-19-2018, 12:02 AM."pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
Re: Weird SSD Issue
Originally posted by junktv View PostThat deoxit is expensive.
But I had to get mini squeeze tubes of the "red" and "gold" to clean a tape deck rec/play switch.
It wouldn't stay "good" after repeated attempts with CRC 2-26.
Originally posted by junktv View PostAny stuff cheaper and available at stores? I'm sure I could use something like that. I know I have some pots and switches that need cleaned.
Also works good on DIMM and card edge contacts with either sturdy paper towels or swabs."pokemon go... to hell!"
EOL it...
Re: Weird SSD Issue
Originally posted by stj View Postit's probably in secure mode - like a password - send a full erase sequence to it.
Don't use the "Sleep" button in the Parted Magic disk utility menu-> There's a bug that makes the BIOS state fucked up and apparently causes motherboard BIOSes to keep falsely reporting an overclock failure, possibly until you clear the CMOS!ASRock B550 PG Velocita
Re: Weird SSD Issue
I tried to use an OCZ boot disc to secure wipe it but it immediately fails (forgot what the error was). Likewise, I couldn't find any OCZ master passwords online.
I'm all ears to other suggestions (or if you happen to have the OCZ master password, no it's not Toshiba's 32 spaces, I tried).sigpic
Re: Weird SSD Issue
Well, it's not really a OCZ this drive, but a rebaged Toshiba drive.
So you might need to use Toshiba's tools for it (if such exists).
If not I've had success with Linux hdparm: https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
However please exhaust all other options before you try that.
For example the MS-DOS utility hdderase.exe is a "safer" tool..."The one who says it cannot be done should never interrupt the one who is doing it."
Re: Weird SSD Issue
Originally posted by Per Hansson View PostWell, it's not really a OCZ this drive, but a rebaged Toshiba drive.
Topcat didn't set it... it set itself due to a glitch of some sort?
Bricked?sigpic
Re: Weird SSD Issue
This is a piece of cake under Linux. With ATA secure erase, you set the password, then let it complete.ASRock B550 PG Velocita
Re: Weird SSD Issue
Originally posted by RJARRRPCGP View PostThis is a piece of cake under Linux. With ATA secure erase, you set the password, then let it complete.sigpic
Re: Weird SSD Issue
Originally posted by ratdude747 View PostOne issue... I don't have either the user or the master password! Both methods seem to require one to know the password already... which I don't since it wasn't set by a conscious person.
Bricked?
Re: Weird SSD Issue
Originally posted by ratdude747 View PostCan't... if you don't have the current password, you can't set the new password. If this isn't the case, please give me the command for such, as all the hdparm stuff I found required the existing password and running off a live arch stick I couldn't get anywhere.
And you can normally set any password, just not too long, I would try 12 characters. (normally without an existing password)
And if it shows "frozen", put the PC to sleep, with the desktop menu, then wake the PC back up.ASRock B550 PG Velocita
