Extend Dell monitors result Vertial+Horisontal
    hi I have connected a Dell 2005FPW to my Dell Latitude E5400 results dell 2005 Vertical and the laptop Horizontal.The problem can not be fixed in settings I use windows 10 recently installed
    what can be done to fix the problem?
    Re: Extend Dell monitors result Vertial+Horisontal
    Try holding the CTRL + ALT + UP keys together to rotate the screen back to normal.
    If this doesn't work, check the graphics control panel to see if you can rotate the display from there.
      Hi thank you no it dint work and in the graphics control panel there is no option
      to ontrole the sreen position
