asus x555ld not turn on.
    hi all, I need your help I have in my hands an asus x555ld that does not turn on, but when I connect the board to the source I have a power consumption and the cpu heats up. I have the 19v, 5v and 3.3v on the board. I do not have the SCHEMATIC of this board but I already saw in the forum the SCHEMATIC repair. Someone has an idea of what this malfunction might be. thank you all
    Re: asus x555ld not turn on.
    To post the correct boardview I need the motherboard version, but try to programm the bios first.
    For the bios I also need the type of video card (number on the chip)
    usually this type of laptop requires a reprogramming of the bios if all voltages are ok
      thanks for reply, it is a asus x555ld rev 3.1
      nvidia n15s-gt-s-a2
        i think is not a bios because i just change and the resulte is the same, no turn on and the power sulpy show consumption less 1amp, and cpu heats up. cpu is onboard
          this is boardview for your model,
            thanks. its possible the cpu is in short?
              i have the capacitor PC9100 in short. i remove the capacitor and the short to be continued.
                How much resistance to GND is on 1.05vs ?
                  pin 1 3.10
                  pin 2 0.09
                    Did 1.05vs exist on pin1 before removing this capacitor? I mean how much voltage on pin1?
                    it would be better solder the capacitor back onto the board.
                      no, i just remove and test the line, and put it back again. not power on without the capacitor
                        its normal the cpu have 1.08vs without the power on the botton on?
                          when the laptop is off, 1.08vs should be 0v. Does the fan spins? Any LED gets on or blinking?
                            i think the same, but in this case the cpu heat up after i plug the ac.
                            no leds and no spin, and i have the 3.3v in the botton on / off
                              does the GPU get warm? does the cpu get too hot or a bit warm? Now, measure resistance and voltage on all the coils you see on the mainboard, when the laptop is off but the AC adapter is plugged in. (It is after midnight here. I am going to sleep. )
                                thanks for the help. its get warm to burn your fingers. but I found something strange, I have in the gate of the mosfets PQ8801 and PQ8802 24v, I already went to measure to the pwm and leaves the 24v from there. should be 19v
                                  how much voltage is on the other pins of PQ8801?
                                  how long does the cpu take to get hot?
                                  is any heatsink installed on the cpu?
                                  is GPU hot too?
                                    its correct, 19v. only gate get 24v. in the boardview say 19v in the gate, and i have an equal board here but damaged too and it leaves 19v of pwm PU8800.
                                    yes i have a heatsink installed for the cpu not to heat too much, it only heats in the small part of the cpu, in gpu I think.
                                    gpu nvdia not heat.
                                    on the whole board is only heated in the cpu.
                                      probably, measuring PQ8801/PU8800 does not help find the problem. you should measure voltage on the big coils on the board and report which ones have voltage by their names which start with PL...
                                        ok. i just do it now...
