Jetway 830 CF v3.0
    Re: Jetway 830 CF v3.0
    Mr. Wilson,
    I have a Jetway 830cf. Removed bad caps to left of cpu fan about a month ago. (12 caps) Have to order new ones and forgot if they are all 2200uf,6.3v,105c, or if some were 1500uf. If u remember pls post for me. Thanks....
      Ok
      Here's what I have replaced
      12 of 6.3V 2200uF
      5 of 6.3V 1500uF
      1 of 10.0V 1500uF
      6 of 10.0V 1000uF
      1 of 16.0V 470uF
      Replaced them all with Panasonic FM
        Mr Wilson,
        Thanks for the "recap" on the caps for the Jetway. U are correct on the MOBO being difficult to get a good solder joint. I recently capped an Acer S58M and it went without a hitch using 60/40. For the Jetway i got a 40w iron and am going to use the high-tech silver-bearing solder 62/36/2.
        Thanks again about the caps. I have CRS at 61 & need all the help i can get......
          FWIW
          Once you have replaced a cap...
          Before snipping leads, test physical integrity of joint(s) by
          moving the capacitor slightly.Just enough to test if
          the unsnipped leads move!
          Cap lead movement a particular problem with this mobo.
          Post solder joint, the connection should be shiny not
          dulled. Otherwise considered a cold or bad joint.
          HTH
            Thanks for the info. Am just getting into repairing mobos & such. My brother did all that for me but he passed on at 54. My area is software. Started with plain DOS. Move to windows was excruciating. Anyway..Started this cause a friend gave me a 19"LCD TFT monitor that the power light would stay on but no screen. After two weeks of research on web & forums discovered it was due to "dry" solder joints at the inverters. FIXED!!! Now have a nice 19" LCD monitor. Thanks for your help. Have replaced the 3 bulging GSC Caps 1500uf, 6.3v, 105c. Had them on hand. Others are ok at this time. I have 7- 2200uf, 16v,105c , 1-2200uf,6.3v,105c vent?,1-2200,6.3v,105c, 3-2200uf,10v,105c to go where the 12 are to the left of the cpu. Will it be o.k. to mix the voltages like this? And also, what is a capacitor that says "vent" on it? It also has name of mfg. on it...
              Very probably the mfg of the cap - or, that is, crapacitors
              Good rule of thumb to stick with is;
              When doing a recap, replace them all with known good brands.
              For sure, it 2/3 have failed, the ESR on the others will point
              to problems, if not now, then very near in the future.
              To test the caps, if you have an ESR meter to hand, you
              can test the caps in circuit on the mobo. Also, can
              use the low ohms setting on a multimeter to determine
              if a capacitor has gone s/c or reads anything above
              a minimal (very) resistance.
              3.3V rail requires 6.3V capacitors
              5.0V rail requires 10.0V capacitors and
              12.0V rail requires 16.0V capacitors
              3.3/5.0 could use 10.0/16.0v respectively
              Never undervolt a capacitor on the equivalent rail, so...
              12.0V - no 6.3V or 10.0V caps
              5.0V - no 6.3V caps
              You can marginally raise the capacitor replacements such
              as 1000uF original, replace with 1200/1500uF
              Exercise caution- conduct your research and make sure
              you are replacing with the correct matierals.
              It is easy to make a mistake, such as correct polarity etc.
              Good Caps thread
              see further https://www.badcaps.net/forum/showthread.php?t=414
              Bad Caps thread
              see further https://www.badcaps.net/forum/showthread.php?t=388
              Also, search the forum, there is plenty of good advice and shared experience.
              HTH
                Thanks....
                  Got all the caps in. No Go. Will not post. Cpu fan comes on, cd rom light, and hard drive light stays on. Green light on monitor never comes on. I think i need to go ahead and order the correct Caps and recap the board. Using a "hodge-podge" of diff caps seems not to work. Thanks for all your advice. Will have to order caps online since none of the local electronics stores have these specific caps in stock. Will let u know the coutcome after i recap with correct cap values. Thanks again....
                    Originally posted by JEWilson
                    Odd issue with this
                    Rec'd board dead - was recap city
                    Most of the caps required replacement
                    Anyway, recapped these with Pana FM
                    Got some memory from eBay
                    2 of Crucial 512MB PC133 ECC Unbuffered
                    Using MemTest86 v3.3 to test the RAM
                    1st stick inserted DIMM slot 1 - Ran Test 5 and 8 for 20 iterations
                    Took some time - but tested ok
                    2nd stick inserted DIMM slot 1 - Ran Test 5 and 8 for 20 iterations
                    Tests ok
                    Inserted both DIMMs in slot 1 and slot 2
                    Test 5 fails - get bad memory address recurrently
                    I suspect this may be more of a problem with the mobo as opposed
                    to memory.
                    Thinks I'll re-check the traces and cap ESR on the DC-DC regulator
                    for the RAM
                    Any suggestions?
                    i got a 830ch version and there was a total of 18 bulging and/or leaking caps. every cap on the board is a GSC. THIS ONES FOR THE BIN
                      Is the memory *known good* in other machine with this same tests? I don't trust ebay till I'm 100% sure *especially* the generic memory, and I still test to make sure with used brand name memory (like made by samsung, micron etc stickered on as OEM for other makers, not like kingston, OCZ etc).
                      One more thing, yes, do all the caps for the memory also.
                      Cheers, Wizard
                        Y - the memory in known good
                        Only seems to work with 2 of 128MB ECC Unbuff MSC branded DIMMs
                        in each slot. That is for ECC Unbuff memory of course
                        Don't appear to have the same issue with non-ECC DIMMs.
                        Odd
