Rebuilding & resurrecting my first dual-core system
The board itself seems to be in good condition, from testing it's had no troubles with an overclocked Opteron 175 and 4x 1GB DIMMs in it.
The problem is, the PCIe slots don't work. Given the numbers of sad looking caps around the slots, this isn't surprising (one of the caps started smoking in the first testing POST!).
Runs fine with a PCI video card which is how I clocked the CPUs and tested it.
The caps around the CPU socket are all sealed jobbies, so I'm planning on leaving those alone and just replacing the swarm of KZG's everywhere else.
Current count (rev 1.01 board)
3x 16v 1000uf around the CPU aux power socket
2x 6.3v 1800uf at the molex EZ_Plug
24x 6.3v 820uf all over the board (many vented)
2x 16v 470uf under PCIEx4 & PCIE16_2 (x4 right next to a 6.3v 830uf; better not get 'em confused!)
11x 16v 100uf (which I'm presumung don't need replacing)
I'm logging these results for a local forum search here
Replace caps on ASUS A8N32-SLI Deluxe? (2014)
ASUS A8N32-SLI Deluxe (2012)
Help Identify Caps on Asus A8N32-SLI Deluxe (2005)
Keeping in mind whats available in Australia in 2018/2019, what would you suggest I replace these with?
I consider this system to have some sentimental value, so I'd like to do the job properly and am thus looking to avoid whatever no-name cheapie low-ESR caps are available from my local electronics store.
cheers
Aeth..
cheers
Aeth..
