View Single Post
Old 05-16-2019, 11:16 AM   #17
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Harman Kardon AVR 270
Your power supply is working ok, I suspect there is a fault in one of the amp output sections. place your meter probes on each speaker output terminal and turn on the amp, you should see 0 volts, if you see more than a couple volts on any of the speaker output terminals, that section has a fault, you will likely need to power of the amp between each speaker test as the amp will shut down.
R_J is offline   Reply With Quote
