Anybody know the technical name of switches these are that are circled in red? The top one is the power lock and the second one down is the automatic power window switch out of my car. The lock still works but the window one doesn't. Just wondering if its possible to just to replace the switch as they want a fortune to replace the whole part. Thanks.
Power windows automatic Switch
Re: Power windows automatic Switch
Are you sure its the switch thats bad? It should be easy to check it with a meter. they could be double pole double throw, on-off-on momentary center off
Probably easier to find one at an auto wrecker, or there could be after market ones on line. they do list similar itemsLast edited by R_J; 02-12-2018, 03:14 PM.
Look for a logo on the switches, to tell who makes them.
In all likelihood, they are Kyungin, a Korean make and hard to find.
You can get the whole door/window switch assembly off eBay or Ali.
Usually the door wires break, in cold weather, at the hinge point.
Depends on what car is this usually they are integrated with the board that is underneath. The board might be a part of the internal network (CAN) which contains other features in your car.
I would try to fix this or as other suggest check wires.Last edited by gabik111; 02-12-2018, 08:11 PM.Laptops and computers repair.
It calls limit switch. It might need some service (I did it in my Sienna when there was an issue with automatic door) - just need some cleaning and greasing. It require to deassembly the motor housing if it is possible (some motors are assembled permanently).
Some motors have an electronic limit switch which brakes the power when motor current is higher than some programmed value (when the motor gets mechanical resistance it needs more power=current to operate then electronics sees that and shutting off motor power).Laptops and computers repair.
