Aspire E1-572g / mainboard V5WE2 LA-9531P
    Hi, i'm having some problems in troubleshooting this motherboard.
    After a drop (while it was powered-on) the notebook turns on only for 2-3 seconds and then turns off. There is no display.
    Battery charging seems ok, and i get + 3VALW and + 5VALW, but no +3VS and +5VS.
    I noticed that SUSP# is always LOW (but not shorted to gnd), so the U11 (page 38 on schematic) does not power +3VS and +5VS.
    anyone know this problem and/or can help me?
    thank you in advance!
    mainboard: V5WE2 LA-9531P Rev: 1A
    schematic pdf here: https://www.badcaps.net/forum/troubl...atic-boardview
    Re: Aspire E1-572g / mainboard V5WE2 LA-9531P
    Check PU401 pin5/2 , PU402 pin7/2 U11 pin 1234567 , U28 pin 9 67 2 37 6 14 65 95 127 110 112 115 116 100 101 Voltage
      hi, thanks for your reply, here are the voltages you request:
      pu401
      pin 2 -> 3.3
      pin 5 -> 3.3
      pu401
      pin 2 -> 3.3
      pin 7 -> 19
      u11
      1->3.3
      2->0
      3->0
      4->5
      5->0
      6->5
      7->5
      u28
      9-> 3.3
      67-> 3.3
      2-> 0
      37-> 2.9
      6-> 0
      14-> 0
      65-> 0
      95-> 0
      127-> 0
      110-> 2.8<->3.3
      112-> 3.3
      115-> 3.3
      116-> 0
      100-> 0
      101-> 0
        pu401
        pin 2 -> 3.3
        pin 5 -> 3.3
        pu401
        pin 2 -> 3.3
        pin 7 -> 19
        PU401 Pin 7 LDO +19V is too high it must be +5V test again ! for the moment leave the U11! RSMRST# 0V The Mob will never power ON check the BIOS chip pin 8 Voltage
          you are right, i measure pin 8 (b+)
          pin 7 is 4.45v
            the spi flash is not powered, pin 8 is 0v, it depends from +3VS
            without +3vs i can get 3v3 only on the power button and in the lid switch (both tested, and working).
            edit: which component controls the RSMRST# connected to EC_RSMRST#?
              this MB continence 2 BIOS chips main +ec bios page U29 check all pins for Voltage , the 2end bios will powered on S3 or S4 stage, your Adapter is not commination with the SIO Chip U28 pin 65 0V trace it back !
                in this Mob RSMRST signal is generated from Super I/O chip it tells the PCH to wake up signel all Voltages ok
                  U29 is unpopulated, it use KB9012 with embedded ec flash, and u29 header is not powered.
                  u28-pin65 is ADP_I. also pu201 is unpopulated
                  i'll check pu301
                    Hello,I have your same issue. Did you solve it?
                      Hi, no. Still unsolved.
                      A customer brought me another computer with the same motherboard and same problem after his cat broke the keyboard with his fingernails.
                      I think the problem may be the ec (broken or to be reprogrammed, but I don't have the programmer). i'm waiting for another working board for tring to swap the ec.
                      P.S. this guy has solved with bios reflash: https://www.badcaps.net/forum/showth...ighlight=9531p i don't solve with this solution, but you can try...
