Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Hi Vince . I was away this afternoon and just got your pm. I tried the link but I'm getting an error file not found etc. Thanks for your help with this.
      Does some have a dump for
      Vestel 17Mb82-2 ?
      I'm having troubles finding a working download link.
      I tried the update from the usb stick and freezing the ICs with no luck.
        This is what i got sent re firmware
          Thanks Vince for the trouble you took. I'll let you know how it goes with the flashing..fingers crossed.
            Unfortunately it didn't work But it was worth the attempt. maybe not the right software or maybe other faults with the mainboard I did notice that
            the firmware was mb62.bin instead of mb60.bin..? so not sure if important.
            any way these damn vestel tele's are a pain. Thanks again Vince for all your help.
              i have emailed and asked him about the mb62 vs mb60 just waiting on a reply just in case he uploaded the wrong file
                NEO LED-22135US
                17MB82S
                MT5820LUNU
                U10-W25Q16DV
                U-12 W25Q64FV
                Panel: AU M215HTN01.1
                you can dump this tv. thanks to who can help me
                  Well I managed to get an mb60_en.bin file for a TOSHIBA 22DL833R and the tv is working but the panel is wrong so it does look like an nand corruption was the problem, if only there was a way to get the panel file and modify the firmware...
                    in a thread i was reading a while ago someone i think removed the panel file from the firmware and when the set started up it rewrote its own from the panel in the set i will see if i can find the thread as cant remember the exact mainboard or what the person removed and what it fixed etc.
                    last post in this thread
                    https://www.badcaps.net/forum/showth...estel+firmware
                      yes that looks interesting alright..seems difficult enough and lots of time
                      maybe have go. The correct mb60_en.bin file would be so much easier though
                        maybe find a cheap mainboard on ebay for your tv copy the files you need from it and re sell back on cheap fix on yours then thats if you can copy the ics firmware of course.
                          Sorry didn't make notes on board number.
                            does anyone have a dvd eeprom dump of Apex AD-1500?
                              Rca LED40G45RQ
                                Originally posted by mariorocco
                                Qualcuno ha il dump per questo apparecchio?
                                MARCA: Trevi
                                MODELLO:LTV 2026HDT
                                MAIN:T.MSD309.B81B 12115
                                PANNELLO:LC260EXN SD A3
                                SPI:25Q32B
                                Try this hopefully it works
                                  Hello. Maybe someone has the firmware for Orion CLB32D700 MAIN:
                                  TP.MSD309.BPS88
                                  Flash 25Q64?
                                  THANK YOU
                                    TP.MSD309.BPS88
                                    Flash 25Q64?
                                    THANK YOU
                                    Try searching thread
                                      I tried to look for the firmware, but it was not found. On the manufacturer's website there are no, on different forums searched, but there is nothing. Firmware from other models on this chassis do not work correctly.
                                        Dump for 24" 17MB82S
                                        Panel type with T-CON on board.
                                        Symptoms with normal 32" dumps - picture is upside down, and solarized
                                          Hi Guys
                                          I am new here and I am wondering if you have an edid eprom dump for Fujitsu P50XHA40US main board M04AY04 8118781040 please. Its for my own TV which my satelite box damaged the 24C02B IC304(short circuit).I hope this is posted in the correct section.
                                          Best Regards
                                          Bill
