View Single Post
Old 05-04-2013, 09:45 AM   #8
LLLlllou
City & State: NJ
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
Default Re: NAD C272/C372 filter cap failures
Quote:
Originally Posted by Hyltz View Post
My apologies "retiredcaps"
The NAD 372 main caps are 10000uf, 80v, 105 deg, 35mm dia.
I have found some Panasonic caps to replace ad they are 105 deg's. But was wondering if there where better caps i could use. Say Nichicon?
Panasonic is as good, if not better than, Nichicon, depends on the series, but Panny is one of the only manufacturers that has NEVER had a bad series.
The extra unpopulated spots on the board allow you some upgradabillity.
Removing all 4 10,000uF 80V caps, and replacing them with 6 8200uF 100V caps, means you never have to worry about overvolting them again, plus you get a little increase in capacitance.
Digikey has these:
http://www.digikey.com/product-detai...0651-ND/272791
Panasonic T-HA series, 105 deg., massive 5A ripple rating, 35MM diam. Problem is these are 4 terminal, so check the data sheet to see if they will fit, looks like the board has extra holes for 4 pin caps, but they may not line up correctly. They' also 80MM high, you didn't mention how high the originals are.
LLLlllou is offline   Reply With Quote
