For those that swear by KZG... :(
    Re: For those that swear by KZG...
    Is this a good motherboard ?
    http://*************/a/img811/2263/p1000603e.jpg
    I'm slowly building a new rig.
    http://www.hse.gov.uk/pubns/indg305.pdf
      Yes, it's good.
        It's so-so.
        "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
        -Leonid Brezhnev (On the Yom Kippur War)
          Originally posted by Wester547 View Post
          ^ You are fortunate that those KZGs have not failed yet after all that time, though it's possible they have since they can easily fail without any indication in terms of sensory (and your computer may not POST if you reboot...).
          *snip*
          Not surprised they failed, the VRM circuit is one of the most stressful parts of the motherboard (if not the most).
          At least mine aren't in the VRM (it has Nichicon for the CPU and NB power and Rubycon for the SB power). The KZG seems to be powering the onboard NIC and such.
            Originally posted by mockingbird View Post
            It's so-so.
            7 stand off holes in motherboard don't fit any ATX case, and you failed to spot it.
              The motherboard will fit in any decent case, and that antec (if you have the antec) is one. It's a standard ATX motherboard and the location of the holes are standard according to ATX, so you have a hole for a standoff for that 7th motherboard hole.
              The case has screw holes for several motherboard styles. You take the motherboard standoffs (the gold things) and you put them in the proper holes on the case, then you install the motherboard.
              Read the manual :
              See page 6, it says the case comes with 9 of those standoffs, 4 are preinstalled but removable
              The motherboard SHOULD NOT have any traces or contacts in the spots where you usually have a standoff for the ATX standard, if you have a standoff touching something on the board, that standoff is in the wrong place. But just don't put a standoff if there's no need for one.
              Anyway, we've been going in this thread for a page or so already, and it has nothing to do with the KZG series capacitors. I will suggest to the mods to split the off topic posts into another thread.
                Most cases don't have a standoff for that 7th hole (closest to the front). It's not a problem, though. Just leave the screw out. The other 6 screws are fine.
                  Here's a shot of my Asus A7N8X board. I bought it new in the box about two years ago. It suddenly died about 3 months ago. Inspection revealed that seven of the eight 3300 ufd KZG capacitors were buldging. The other capacitors on the board are OST RLX except for two Rubycon MBZ's, all of which look OK. I recently bought a used A7N8X that has MBZ's instead of the KZG's. Otherwise it's the same. It seems to work OK. I can't find any date code on the board or its box that might indicate when Asus changed vendors.
                    Just repalce with some verified caps and will be as new.
                      And if you don't want to be doing it again, replace the OST too
                        Looks like a 2004 and I had a feeling that it was likely a 2004 when I saw a sticker said that the board was manufactured in China.
                        2004 A7N8Xs are usually China and have KZGs.
                        2002s and 2003s are more likely to be manufactured in good ol' ROC.
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        16 GB AData XPG Spectrix D41
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
