ms-7957 ver 1.0 HP ProDesk 490 G3 bios
    Hello everyone
    i have a motherboard ms-7957 ver 1.0 HP ProDesk 490 G3 and it has a corrupted Bios, and i serch for 3 days for the bios to flash with usb programmer and coudn't find a working bios flash file...pls help me i'm begging you.
    Re: ms-7957 ver 1.0 HP ProDesk 490 G3
    Originally posted by GraveRaven View Post
    Hello everyone
    Post your bios backup here .
      HP ProDesk 400 G3 MT
      MS-7957 VER 1.0 16MB
        Salam O Alaikum.. thank you brother... i try this bios its working perfect...
          working
            ok very thanks.it is worked
              May I ask you the exact way you do the flash ?
              I've read in another part of the forum that we can flash the bad bios with a usb key
              I've taken an fat32 8 gb usb key,
              i've shorten the bbr connector on the motherboard, put the usb key on a USB2.0 port,
              start the computer, and let it go for at least 5 mn, but it doesn't seems to do anything.
              Can you help me guys ?
                https://www.youtube.com/watch?v=DWWigscuQDY
                  thanks for your answer, i'm going to check this !
                    I programmed the BIOS with this file.
                    At startup I have inscriptions:
                    "WARNING Machine is not in committed state.
                    System is booting in manufacturing program mode 28"
                    Then it loads normally.
                    How can I fix this?
                      How can I fix this?
                      try this..if you don't succeed, look for other videos...
                      https://www.youtube.com/watch?v=DwcWzGCoj9A
                        Re: ms-7957 ver 1.0 HP ProDesk 490 G3 bios
                        I can't find this tool. I see it is for specific laptops.
                        My system is as follows:
                        HP ProDesk 490 G3 MT Business PC
                        SN: CZC61498SM
                        Prod.N: P5K11EA#AKS
                        I used a file
                        MX25L12805D@HP ProDesk 400 G3_ME_Cleared.rar
                        by "abdnassar" #3
                        The inscriptions
                        I can't remove them.
                        Please help!
                          SN: CZC61498SM
                          Prod.N: P5K11EA#AKS
                          I used a file
                          by "abdnassar" #3
                          The inscriptions
                          Please help!
                          If you made a bios backup before trying the other bios post it.
                            This is the original BIOS.
                            But with it the computer stopped working (black screen)
                            So I had to program it.
                              HP ProDesk 490 G3 Microtower PC
                              Become a Badcaps supporter
                              Thanks to all supporters.
                                Excuse me!
                                I can't delete this post I duplicated!
                                  Thank you very much!
                                  I will try it tonight and write how it is!
                                    Hi hoaca388!
                                    I tried your BIOS and it works.
                                    Only at startup I get a message:
                                    "Product Information not valid. The following product information programmed into system boards is missing or invalid.
                                    System Board (00A) - System Board CT Number
                                    Press space bar to continue boot or 'Y' to enter missing information."
                                    I have nowhere to get this CT Number.
                                    What would you advise me to do?
                                      hi hoaca388!
                                      I tried your bios and it works.
                                      Only at startup i get a message:
                                      "product information not valid. The following product information programmed into system boards is missing or invalid.
                                      System board (00a) - system board ct number
                                      press space bar to continue boot or 'y' to enter missing information."
                                      i have nowhere to get this ct number.
                                      DMI supplement
                                        DMI supplement
                                        Hi hoaca388!
                                        Many thanks for the latest BIOS!
                                        Works perfectly!
                                        Congratulations on a wonderful job!!!
                                        I have the following question regarding the BIOS:
                                        In the original BIOS, I have an OEM Windows 10 serial number.
                                        Can I get it into this new BIOS?
