I have a swollen Sanyo WG 2200uf cap removed from the board and reading 8000uf with an LCR meter and a DMM. I always thought bad caps capacitance goes way down when swollen or leaking.
Bad cap reading 4x high?
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%Tags: None
Re: Bad cap reading 4x high?
What resistance do you get when tested it in Ohm mode? What ESR do you get when tested with ESR meter?Never stop learning
Originally posted by budm View PostWhat resistance do you get when tested it in Ohm mode? What ESR do you get when tested with ESR meter?
Ryzen 3600x
FX-8802 Iron
First off the ESR 0.24 ohms is a give away any way
It should be .02 anyway and the UF reading is way off to9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
Originally posted by sam_sam_sam View PostFirst off the ESR 0.24 ohms is a give away any way
Here is an example. Brand new 1000uf Panasonic FM
Ryzen 3600x
FX-8802 Iron
Originally posted by jayjr1105 View PostIBrand new 1000uf Panasonic FM
The ESR might be a bit high depending on which exact 1000uF cap you have. Check it against
https://cdn.badcaps-static.com/pdfs/...404c12c252.pdf--- begin sig file ---
--- end sig file ---
Originally posted by stj View Postthey are very accurate if they are calibrated.
Originally posted by retiredcaps View PostElectrolytic caps are usually +/- 20% of their uF rating. So a 1000uF cap reading 1048uF is okay.
https://cdn.badcaps-static.com/pdfs/...404c12c252.pdf--------------------------------------------------------------
Ryzen 3600x
FX-8802 Iron
Bigger ones (=High Voltage) usually are a bit under the specified value.
ie for a 470uF capacitor you can assume something around 440uF or something like that...
It looks like the leakage resistance causes the fault capacitance reading.
If you put 100K, 47K resistor in parallel with that Panasonic cap, what will it show on your cap meter?Last edited by budm; 02-19-2018, 06:56 PM.Never stop learning
Originally posted by stj View Posti recommend a 0.22uf film cap for calibrating.
if a .1uf cap is actually 0.099uf the tester wont like it.
Do you think my ESR readings will improve that much once calibrated? I have tested a ton of low esr caps, never once seeing anything .0X or lower. I thought that LCR tester is just junk.
Edit: I can put two .1uf's in parallel can't I?Last edited by jayjr1105; 02-19-2018, 07:46 PM.--------------------------------------------------------------
Ryzen 3600x
FX-8802 Iron
the parallel method should work.
you should read my very long tester thread!!
https://www.badcaps.net/forum/showthread.php?t=50720
https://streamable.com/acx9mThe art of fighting without fighting
1-6-4 Temperature Characteristics
Aluminum electrolytic capacitors have liquid electrolyte. This electrolyte has properties (conductivity, viscosity, etc.) that have rather conspicuous temperature characteristics.
Electrical conductivity increases as the temperature increases and reduces as the temperature decreases.
Therefore, the electrical characteristics of aluminum electrolytics are affected by temperature more than other types of capacitors. The following section explains the relationship between temperature and capacitance, tangent delta, ESR, impedance and leakage current.
1) Capacitance The capacitance of aluminum electrolytic capacitors increases as the temperature increases and decreases as the temperature decreases. The relationship between temperature and capacitance is shown in Fig. 1-9.
2) Tanδ, Equivalent Series Resistance (ESR), Impedance The Tanδ, equivalent series resistance (ESR) and impedance changes with temperature and frequency. An example of the general characteristics is shown in Fig. 1- 10 and 1-11.
Originally posted by victor_cj View PostLCR-T4 versus BK 880
https://streamable.com/acx9m--------------------------------------------------------------
Ryzen 3600x
FX-8802 Iron
