Hello, I have a MacBook Pro 15 inch 2018. A1990 Board 820-01041-A. The MacBook has water damage. It works but the display stays black. I took a picture of the LVDS connector. there you can see on the thick pin over IPX that there was a short circuit. there is also zero volts. Have any of you had the same problem? Thanks
Macbook A1990 820-01041-A Dark Display
Re: Macbook A1990 820-01041-A Dark Display
Hi. Best to use pin numbers from the BV file for this logic board.
Can you measure and post your voltage readings of J8500?
In the meantime, need to collect the 10,000 leaves in the backyard - it is a favorite past time. Want to burn them along with the audio equipment used by the neighbors for their outdoor karoake sessions.
Fault may be that U9850 is damaged (MUX).
See 'NO IMAGE' here:
https://repair.wiki/w/A1990_2018-201...ar_MacBook_Pro
If you suspect U5210 - measure the voltage of the I2C lines on both sides of U5210.
That is,
I2C_DISP_SCL
I2C_DISP_SDA
I2C_TCON_SCL
I2C_TCON_SDA
The link doesn't work.
