cables
    cables
    One time i was in a pinch, summer out, too hot for attic adventures and i needed to run another cable to my closet
    there was already one cable ran and i couldnt use a switch because of how i have design the layout
    so i re-wired the existing cable into 2 cables, this works becasue CAT5 cables only use 4pairs of the wire, there are 4 remaining pairs left, i seperated the 4 extra wires out the end and added plugs to both ends. works great and i still get full 100mbps throughput local.
    Re: cables
    its amusing how you can violate the recommended
    - stick cables with hot glue
    - run them next to power cables
    - bend them pull them
    i only had probs once by securing a cable with nailed in cable clips
    most probs are by incorrect pinout at connector or bad crimping of connector. i always test the cables with cheap network tester though
    funny how there is a magnetic like attraction of the cables to the feet of the ladder when you are pulling cables.
      Re: cables
      totally agree, or around your foot while stretching on the ladder.
      Cat5 cables seem to be able to take a lot, over flouro ligh fixtures, fridgerators, AC unit... i suppose it all depends on the requirments though..
      i have had problems with pulling but that was becasue of my patients levels, a big knot and a truss
      Cat6/a and fiber on the other hand.. like a woman.
