RUNTK 5351TP No Picture Failure
    Re: RUNTK 5351TP No Picture Failure
    Maybe, hopefully not the same case for mine if so Im out of luck.
      The KL5T3067 can also fail? but its a good bet that if the VCC 3.3v is missing changing the ISL9860 will do the trick, As soon as there was a good supply of new boards. I stopped repairing them, with the customer paying repair cost I just brought new.
        Yes read what the other chap said further up.
          I did read the above? I am just adding that if you do not have the VCC 3.3v the chances are its the ISL9860 that has failed or has not been fitted correctly.And not the KL5T3067 that is at fault
            reball . change again isl . still no image. any help ?
              Its really hard to say with out the board here in front of me sorry :L
                Well chaps good news here, replaced Ic200 and the set works Will upload pictures of work later.
                  Hey is it the same board RUNTK 5351TP ZA and RUNTK 5351TP ZA model?
                  I need to order new board and i have ZA model but seller have only ZZ model
                  ...the quieter you become the more you are able to hear...
                    Hey i find new bard and install it, i get screen but have some lines. Any ideas what is this?
                      Images coming soon totally forgot. Also RTStorm thats a failed panel them lines
                        But wheb i disconect one flat cabke the line are gone
                          Yeah thats because the shorted panel drive isnt getting power so it cant pull the lines up.
                            Originally posted by angel-boy View Post
                            i have a RUNTK 5351TP , i change the IC200, ISL, but still no image, the fuse is good, any ideea ?
                            IC100 KL5T3067
                            http://www.elforum.ro/topic/119716-t...40f5500/page-2
                            The art of fighting without fighting
                              Forgot to upload pics of this fix, here they are just forgot. One by one as Vbullet will not let me do more than one at a time on mobile device. First one is old Ic removed.
                                Second Ic changed flux residue still present.
                                  Third is Ic with removed flux.
                                    Fourth pic is heatsink added to Ics.
                                      5th is working image after I pc change, was preformed ages ago never did a vid and forgot to upload image
                                        I think I'm having the exact same issue (ReeceyBurger just replied to my own thread just a few minutes ago - cheers ). I think I'll try measuring VCC 3.3 first with and without the buffers attached. If I get nothing, the ISL driver is most likely busted.
                                        From what I read on the forum the other chap linked to (I fortunately speak native Romanian ) I should also take readings of VGH and VGL, though I'm not entirely sure what they should normally read. Lots of info here, so hopefully I'll manage to pull though
                                        EDIT: upon reading the Romanian forum thread more carefully, I noticed VGH and VGL should be around 35v and -6v respectively (or real close to that)...is this correct ? The fellow over there didn't have T-con issues after all, so I can trust those readings to be pretty close to what they should normally be - it was a shorted driver on the right side of the screen which dragged down the VGH bus.
                                        Wattevah...
                                          Yeah, heatsinks are a must as far as I'm concerned...boggles the mind as to why so many brands "omit" to add them ! Planned failure at its finest is what I call that ! >_>
                                          Wattevah...
