Working on a Benq FP71G model Q7T4. So far have found blown fuse, bad solder job on cap at C826, 2 blown transistors (those infamous C5707). Also included in attached photos is the MOSFET part number I think user "pecolt" was looking for in the Q7T3 thread.
Benq Q7T4 FP71G
Re: Benq Q7T4 FP71G
Also check the FU MOSFETs one of them usually likes to open.
If one is open both of the monitor blacklights won't turn off when you hit the power button.
Oh yes and were not talking a standard 3 amp glass fuse it's a pico fuse it's a through hole component.
It is black and almost the same size as an IN400X diode but it will say Buss (a fuse company) in green with the voltage and amperage on it.Last edited by Krankshaft; 10-27-2008, 12:38 PM.Elements of the past and the future combining to make something not quite as good as either.
Re: Benq Q7T4 FP71G
i am having the same problem with mine, if anyone is still willing to help, solder on C826 looks fine and broken on mine, will re solder that, also, there is solder missing on one little spoke on the big yellow thing, will re solder them both tomorrow will start with C826, and leave other off and than try it, dosent appear to have had solder there b4 hand
screen turns on for 1 sec, and flash's off
Re: Benq Q7T4 FP71G
how much do you think it would cost to fix all up, not really worth throwing screen away i couldent find C5707 some solder is broken on mine but dose not look to bad, ill just solder it all up, and see how it goes, if it dosent work, will have to take it to the next step and get some parts for it. and see how it goes, how much would it cost for all most common parts which go???
Re: Benq Q7T4 FP71G
Originally posted by zerophotoshow much do you think it would cost to fix all up, not really worth throwing screen away i couldent find C5707 some solder is broken on mine but dose not look to bad, ill just solder it all up, and see how it goes, if it dosent work, will have to take it to the next step and get some parts for it. and see how it goes, how much would it cost for all most common parts which go???
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Re: Benq Q7T4 FP71G
I have the same Problem as FreeGeekVan. So far I replaced the (obviously blown) c712 as well as the c707, c708 and c709 (just in case). I furthermore put in an new Q805 (shortcircuited with IRFU 9024N and replaced al sc5707 with sc5707. I tested the fuse PF 801 and a current can run through. The symptom of a white screen with running backlight has not changed. Does anybody have an idea how to fix my Q7T4? I can not test capacitators so I do not know which other ons to replace. Furthermore my standart electronics dealer (in Germany) does not have any replacement for the c826 which was also one of the most common flaws. I will see if I can get that one elsewhere...
Cheers,
CanadanLast edited by canadan; 03-28-2009, 03:09 PM.
Re: Benq Q7T4 FP71G
Cheers,
Canadan
Re: Benq Q7T4 FP71G
Originally posted by PlainBillI've seen several references indicating a white screen is often caused by a blown smd fuse on the LCD panel itself.
PlainBillThere are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- Intel Core i5-7600K 3.8GHz
- 16gb GSKILL TridentZ RGB DDR4-3200
- 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
- Windows 10 Pro x64
- GeForce GT1050
Re: Benq Q7T4 FP71G
Originally posted by canadanOk, I found the culprit and the fuse you mentioned seems to be blown. I am now thinking of hotrwiring it due to the fact that I don#t have the tools to put in a new fuse that small.
Re: Benq Q7T4 FP71G
Originally posted by PlainBillYou don't have a soldering iron?
PlainBill
And Toasty criticized my 99c soldering iron.. at least I had oneThere are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
Re: Benq Q7T4 FP71G
I do have a soldering Iron, but it is let's say quite one the brink of destruction... It was a fairly cheap one and I can't get replacement tips. To replace the transistors I had to use up quite an exxesive amount of sandpaper on it. But I will probably try to replace the fuse anyway.Last edited by canadan; 04-03-2009, 11:56 AM.
Re: Benq Q7T4 FP71G
Originally posted by canadanI do have a soldering Iron, but it is let's say quite one the brink of destruction... It was a fairly cheap one and I can't get replacement tips. To replace the transistors I had to use up quite an exxesive amount of sandpaper on it. But I will probably try to replace the fuse anyway.
If there is sufficient clearance you don't even have to remove the old fuse, just solder the new on on top of it.
Re: Benq Q7T4 FP71G
Originally posted by PlainBillFirst of all, get a decent soldering iron. You don't need a $200 (US, about $75 Canadian ) soldering station with digital temperature control, but you deserve one where you can at least replace the tips.
- GeForce GT1050
