Vizio P502UI-B1E has no backlight, no voltage from driver board to LED's
    Re: Vizio P502UI-B1E has no backlight, no voltage from driver board to LED's
    budm you saw that i explained i measured the EN pin as you asked and it never spikes?
    and ok i will get that picture
    Don't fear the repair...
      triplefour.... budm's picture shows the '220" or something resistor but your picture shows a "0 ohm" one which is either a jumper or fuse depending on design. Are you checking the "EN" on the side closest to connector?
        Sorry, the thread is getting long and it is hard for me to keep track.
          heres some pics.. i wish there could be more posts per page
            Does this TV have WiFi module?
            http://www.shopjimmy.com/vizio-317ga...ss-adapter.htm
            http://www.shopjimmy.com/catalogsear...zio+P502UI-B1E
            If it does, then try disconnecting the cable going back to the main board to see what happen.
              dimms down to a black screen, even using flash light nothing on screen shows nothing.
                it does have the wifi module and ive already tried that but didnt mention it. it doesnt change anything
                  This is the tough one.
                    Sorry my last post #66 went with #59. same here disconnecting WIFI does nothing.
                      Budm I am going to back out for now as we have 2 different sorta issues, mine when lights dim down instead of holding they go totally out. He has incorrect voltages. Do not want you to get confused anymore than what you are. I just need to find out what control's the dimming aspect. Maybe the same buck regulator does do that i do not know for sure or maybe something on main board controls that signal. And I am getting a head ache from all this...LOL
                        If you need more voltage comparison i will still be watch this thread. Always learning something.
                          Connector CN805 on the LED driver board is the one that gets the BL-ON and dimming control signals from the main board.
                          I can see 6 small signal traces.
                          Can you read the P/N of the LED driver IC's (4 of them)? I.E. U301 to find the spec sheet to find out which pin is for dimming control.
                            i know it doesnt apply to my problem (yet) but im happy to help
                            i think i see
                            AS3820E H
                            1421XBC
                              al1415 could you verify the voltage you have on the ENable pin (pin2) of IC804? easiest way to get is to measure either side of R8219
                              and also if you can, the voltage on C8067 (which is connected to the SS pin)
                              just to see how this IC is actually working, if i am supposed to have voltage at the enable pin for "normal" operation.
                              thank you
                                R8219=4.1
                                c8067=1.8
                                  Budm the chip numbers are:1Z690l2 and ZA4S16. Look for data sheet could not find by either number.
                                    al1415 thanks, so i guess the enable pin DOES have to be on..as well as the SS
                                    im thinking those voltages must come from the mainboard and correspond to the 2 im missing on CN805
                                      i think i see
                                      AS3820E H
                                      1421XBC
                                      https://www.dialog-semiconductor.com/products/as3820
                                        Your P/N is not same tripefour in post 73
                                          Found this link that gave more info on chip..
