The ghetto mod thread
This is a sticky topic.
    Re: The ghetto mod thread
    Originally posted by TELVM View Post
    Rubber bands rock!
    There seems to be some clear plastic sheet between fan & heatsink, what's that for Momaka?
    I like this mod by Momaka and I might use it.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      My ghetto mod for this year must've been a cooling fan to cool myself because it was hot in here. I simply used an Allied AL-8400BTX PSU (the one I've repaired in the PSU section here) and a 92mm AVC 12v fan wired up on the PCI-E connector (at least it's worth something ) along with a jumper wire between green and black. (PS_ON and GND)
      Main rig:
      Gigabyte B75M-D3H
      Core i5-3470 3.60GHz
      16GB DDR3-1600
      Samsung SH-224AB DVD-RW
      Delux MG760 case
        I wonder if my Coolmax PSU fix is ghetto enough... It this jury rig a kludge, bodge, or ghetto fix?
        https://www.badcaps.net/forum/attach...7&d=1501352814
        The two brown jumper wires were added by me to fix the burned track underneath.
        If I had twisted the wires together and left them above the board, epoxied down or not, then I suppose it would count... LOL
          i draw the line at bodging psu's - i dont want to risk anything downstream.
            That's not a bodge but a photo of the very rare solder sloth upside feeding on some vegetation.
              A lot of these are calculated risks I suppose. Main reason why I went ahead and kludge/bodge fixed this is because this is in the primary circuit - if primary fails, everything is down, anyway - unlike if the control circuitry is bodged, then the output could go out of spec and cause downstream damage. The burned tracks were too weak to reuse so I had to use the solder to make up for the loss of the foil.
              I figured that the main risk of repairing this is repeat insulation failure, and that I spent extra effort trying to ensure that it doesn't fail again. I'm not sure how others would have repaired this damage, or could have just treated this as a total loss/parts unit (which I was intending this PSU to be when I first got it).
                i would have cut the burned section of pcb out, and rebuilt it with epoxy.
                then probably lined or partially butchered the casing!
                  Go for it. Just beware that those rubber bands dry-rot and degrade very quickly. When I made that mod, I didn't know better. Luckily I didn't use the computer like that. I replaced the fan with a better one and got rid of the rubber band.
                  Exactly.
                  There's no guarantee you won't get a bad PSU even from a reputable manufacturer that manages to burn itself out and the rest of your equipment. With repaired PSUs, at least I know what was wrong and what I fixed and how I fixed it.
                  lol
                    Here's one from yesterday/today. A vestel taken off the wall still with two HDMI cables plugged in.
                    I possibly should have looked on ebay for a board and I wasn't given the remote so haven't tested it yet.
                    I will be sealing the wires once I've tested the repair as they are bare strands of copper and not coated magnet wire.
                      Maybe we need a different thread for bodge/kludge jobs and leave this one for the ghetto, I think that HDMI fix is too "professional" to be a "ghetto" fix (and perhaps my burned track fix too...)
                        Dang, I thought I've done some fine trace repairs, but never so many next to each other. I admire your patience for this one.
                        On that note regarding removing equipment with the wires still connected... I had a 17" CRT monitor that I forgot was plugged in the wall. So when I lifted it up and started moving it, all of a sudden the CRT pulled away from my hands and fell on the floor. Surprised the crap out of me when that happened. Luckily I have a carpeted floor so nothing broke. Also had a similar accident with the VGA cable plugged in another CRT monitor. But them D-SUB bastards are built tough and made to handle rough handling (lol ).
                        As for ghetto mods, I am working on a video card + fan upgrade for one of my old PCs. Just made a metal bracket to hold an 80 mm fan to the case where the add-on card screw to. Will take pictures when it's done.
                        Yeah, I thought about that too when I made the "Worthless/Pointless" repairs thread. I figured that since a lot of my ghetto repairs are worthless, I wouldn't need to... but now I see that we may need one indeed. In fact, you can see that a lot of the "mods" I posted here in the past are actually repairs.
                          Thank you for your kind words Momaka, it was you worthless/pointless repairs thread I was looking for, perhaps I should have tried harder (used search).
                          The repair probably took about an hour on and off, so pointless from a labour point of view vs cost of a replacement board maybe, but more an exercise in can it be done. Certainly quicker than waiting for a replacement board if I can find one.
                            You guys should see my (soon-to-be-old) work computer.
                            A working TV? How boring!
                              T12 soldering iron stand.
                              ingredients:
                              1 weller iron stand - base section for weight.
                              1 joke stand from china.
                              1 pencil eraser
                              2 M5 screws.
                                ingredients:
                                1 pencil eraser
                                2 M5 screws.
                                Nice work
                                  it's actually more comfortable just throwing the iron onto a "V" instead of poking it into a spring!
                                    Indeed. That's pretty similar to how I made the stand for my soldering station as well.
                                    *Edit*
                                    Looks like I even posted this a while back:
                                    https://www.badcaps.net/forum/showpo...&postcount=290
                                      anyone remember wordless workshop?
                                        Power Mac G4 Quicksilver PSU replacement
                                        Original PSU failed, no power at all, and I didn't know how to fix them back then (6 years ago). So I took an ATX PSU and modified the connector's wiring.
                                        And I added a laptop power brick (from a Compaq Armada 4120) to feed the +24V line (with 20V but it works) as I was using the original Apple display which doesn't have an external power connector. Before that the +24V was feeded by the +5VSB.
                                          Ha, nice! I think I've seen people do/suggest that here before on BCN when those proprietary Apple PSUs bit the dust. It works, so why not.
