View Single Post
Old 04-05-2015, 12:23 PM   #9
capkid
City & State: Federal Way,WA
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: LG 50PT350 sound but no picture
Quote:
Originally Posted by ultimatt View Post
OK...ordered a YSUS board.
One question, when checking the IC's on the Y buffers I should be checking between the ground(s) on the power to the buffer board and all the pins on the IC ribbon connectors to see if I have a short to ground...correct?
Also, If I miss one could a bad IC kill the YSUS board?
I believe you can check that buffer as you described - not sure, though. LGs buffer failures are normally more forgiving than Samsungs, so a bad buffer shouldn't kill a YSus.
capkid is offline   Reply With Quote
