Quote:
Originally Posted by budm
The reason I have you checked the resistance, NOT ESR, is to find out if has leakage resistance that is bad enough to cause the problem or not.
Sorry, I'm somewhat new to this, so need to read more carefully! OK, drained , voltage is ZERO, then tested at 10.003M ohm. disconnected from circuit, drained, tested again at 10 M ohm, this looks OK i would think..
Someone bet on the diodes, i'll go there next unless there are other ideas..
it may take a bit longer to find exactly that diode
Stormy.
