View Single Post
Old 11-07-2007, 09:16 AM   #14
severach
City & State: Michigan
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: Comments on The Recapping FAQ
The cheapo solder stations don't have good heat recovery so they need to run at a high temperature to have enough heat to withstand the shock of cold parts. A good solder station can do the same work much better at a much lower temperature.
What I'd like to find is a needle nose with a curved jaw and a close spring. It would resemble some of the spark plug pullers and does not need to be strong. The jaw should be silicone tipped and thin enough that I can correctly position a cap in the middle of other caps underneath a wire bundle.
severach is offline   Reply With Quote
