need bios lenovo yoga 300-11lbr
    need bios file of lenovo yoga 300-11lbr
    Re: need bios os lenovo yoga 300-11lbr
    up.. plss
      i need it to did you find it please send it to me
        no yet
          up plss
            Hi
            Here next time upload original it's always needed even when it's bad.
            Techman1025
              Originally posted by techman1025 View Post
              Hi
              Techman1025
              still no display.. when i plug in the charger it automatically turn on. steady light on power switch button.
              sorry dont know how to attach file here
                Hi
                Well first is it doing anything different then when you got it after you reflash BIOS ..so if it was dead now starts just no display ...any display on external ? So look how you replyed to me POST QUICK REPLY next to that it saids GO ADVANCED click you will see attachment attach your file and upload your original bios if to different chips like one bios & EC upload load all ...i will take a look at your file and fix them if needed.
                Techman1025
                  Hi
                  Techman1025
                    Hi
                    Techman1025
                    the 1st problem is . it has power or light indicator on power button when switched on but no display. after i reflash the bios . i still got the same problem
                    heres the backup file of my bios.
                      up
                        Hello, my name is Aldo, did you manage to solve the problem of the bios of the lenovo yoga 300 11ibr? If so, can you help me please, I have programmed the bios with the file that was sent to you, but it is the same as your computer when you connect the battery that turns on only and does not give a picture ...
                          Originally posted by aldopc View Post
                          hello, my name is aldo, did you manage to solve the problem of the bios of the lenovo yoga 300 11ibr? If so, can you help me please, i have programmed the bios with the file that was sent to you, but it is the same as your computer when you connect the battery that turns on only and does not give a picture ...
                          you send file and motherboard code what? I try fix.
                            i need Lenovo_Yoga_300-11IBR ec bios pls anyone have share me
                            thank u
                              I have the same problem when i connect the battery that turns on only and does not give a picture
                              did you find the problem ?
                              Best regards
                              JOVY RE7500
                                Best regards
                                try this
                                  The problem is the KBC bios, is a 25x05CL, 64kb, is only avaible paid on others forum. If someone may provide it here will be very usefull. Thx!
                                    Good news for all who have same issue, i found an application
                                    "https://sourceforge.net/projects/innounp/"
                                    which extract the BINs files from an EXE, in this case search for the Update bios (exe) from Lenovo, maybe works for others EXE to extract bios from.
                                    The procedure is like on a CMD prompt: innounp.exe -x nameofupdate.exe
                                    and BOOM! we got extracted the bins EC and MAIN from an EXE update.
                                    Hope to help you folks.
                                      I got the files extracted by starting the bios setup application. Do not quit the program. Then you go to your account\appdata\temp.
                                      Look for the folder with the newest date and time. Then you got the files.
                                      In THIS case, there was one file only.
                                      Not usable for me
                                        Which forum? I need that file.
