Bad cap reading 4x high?
    I have a swollen Sanyo WG 2200uf cap removed from the board and reading 8000uf with an LCR meter and a DMM. I always thought bad caps capacitance goes way down when swollen or leaking.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    Re: Bad cap reading 4x high?
    What resistance do you get when tested it in Ohm mode? What ESR do you get when tested with ESR meter?
      high leakage does that.
        Starts around 1k ohms then climbs and climbs then, in a split second, goes up to 30k.
        Ryzen 3600x
        FX-8802 Iron
          I've seen some LCR meters report incorrect numbers on leaky capacitors. The number is wrong.
            First off the ESR 0.24 ohms is a give away any way
            It should be .02 anyway and the UF reading is way off to
            9 PC LCD Monitor
            6 LCD Flat Screen TV
            1 Dell Mother Board
            15 Computer Power Supply
            All of these had CAPs POOF
              I'm not too sure about the ESR accuracy on that cheap test kit. I have thrown brand new low esr caps in there and it's shown way too high esr as well.
              Here is an example. Brand new 1000uf Panasonic FM
              Ryzen 3600x
              FX-8802 Iron
                they are very accurate if they are calibrated.
                  Originally posted by jayjr1105 View Post
                  IBrand new 1000uf Panasonic FM
                  Electrolytic caps are usually +/- 20% of their uF rating. So a 1000uF cap reading 1048uF is okay.
                  The ESR might be a bit high depending on which exact 1000uF cap you have. Check it against
                  https://cdn.badcaps-static.com/pdfs/...404c12c252.pdf
                  --- begin sig file ---
                  --- end sig file ---
                    I just ordered a .1uf cap to calibrate it. I don't have anything close sadly.
                    I didn't mean the capacitance. I meant the ESR is way too high for a brand new low ESR cap.
                    Ryzen 3600x
                    FX-8802 Iron
                      Yes, smaller ones are usually a bit over that.
                      Bigger ones (=High Voltage) usually are a bit under the specified value.
                      ie for a 470uF capacitor you can assume something around 440uF or something like that...
                        i recommend a 0.22uf film cap for calibrating.
                        if a .1uf cap is actually 0.099uf the tester wont like it.
                          It looks like the leakage resistance causes the fault capacitance reading.
                          If you put 100K, 47K resistor in parallel with that Panasonic cap, what will it show on your cap meter?
                            Figures, I knew I should have just ordered a kit like this. http://a.co/3KgqGtE
                            Do you think my ESR readings will improve that much once calibrated? I have tested a ton of low esr caps, never once seeing anything .0X or lower. I thought that LCR tester is just junk.
                            Edit: I can put two .1uf's in parallel can't I?
                            Ryzen 3600x
                            FX-8802 Iron
                              the parallel method should work.
                              you should read my very long tester thread!!
                              https://www.badcaps.net/forum/showthread.php?t=50720
                                LCR-T4 versus BK 880
                                https://streamable.com/acx9m
                                The art of fighting without fighting
                                  1-6-4 Temperature Characteristics
                                  Aluminum electrolytic capacitors have liquid electrolyte. This electrolyte has properties (conductivity, viscosity, etc.) that have rather conspicuous temperature characteristics.
                                  Electrical conductivity increases as the temperature increases and reduces as the temperature decreases.
                                  Therefore, the electrical characteristics of aluminum electrolytics are affected by temperature more than other types of capacitors. The following section explains the relationship between temperature and capacitance, tangent delta, ESR, impedance and leakage current.
                                  1) Capacitance The capacitance of aluminum electrolytic capacitors increases as the temperature increases and decreases as the temperature decreases. The relationship between temperature and capacitance is shown in Fig. 1-9.
                                  2) Tanδ, Equivalent Series Resistance (ESR), Impedance The Tanδ, equivalent series resistance (ESR) and impedance changes with temperature and frequency. An example of the general characteristics is shown in Fig. 1- 10 and 1-11.
                                    https://www.youtube.com/watch?v=vzoDurlg_jI
                                      I have never from day 1 of owning the LCR-T4 seen a cap ESR that low. Even with brand new caps. I wonder if there's firmware or something to update. I still have some caps coming tomorrow for calibration.
                                      Ryzen 3600x
                                      FX-8802 Iron
                                        >0.1uF capacitor for calibration is the reference, Rp and Rs may make a difference.
                                        On the LCR-T4 PCB, 431(TL431) is the reference for ATMEGA328P-AU.
