Worse than the psu itself is the fact that it powered a quad core PC, 2 dimm ram and 8600GT....
https://www.badcaps.net/forum/attach...1&d=1400287499
There is nothing useful even for parts inside that power supply unit.
The case is thin like tinfoil, the fan had its label loose and the rubber seal wasn't fitting in hole, awfully thin heatsinks, tiny transformers, 330uF primary caps and 1x1000uF secondary capacitor for every main voltage output, without any coil!
There are also the usual 13007 transistors, 20 Ampere schottky rectifiers and 10 ampere STPR1020CT for 12V!!!
I can't believe that this ultra fast rectifier didn't blow considering it powered a Quad core cpu and 8600GT GPU. The PCB is burnt around it. The fan worked at 12V of course!
https://www.badcaps.net/forum/attach...1&d=1400287716
Well, at least it has passive PFC. But wait, I saved the best for the end... This PFC made me suspicious right after I saw it. Let's look more closely:
https://www.badcaps.net/forum/attach...1&d=1400287865
It's absolutely fake!!!
If you are as interested to see what's inside as I was, I took photos of its "core":
I think they waste their money.. They should fake the PFC cable too! Look at the PCB:
https://www.badcaps.net/forum/attach...1&d=1400288885
Like the Powertech gutless wonder psu I got 2 months ago, the PFC connector is on the same PCB track! Mystery solved! Powertech probably also comes in "PFC" editions with fake PFC, so no need for a real connector!
