Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    More files
      Originally posted by turkay06 View Post
      please try..
      This is just a copy of the file I uploaded on page one of the thread. It's for a 32" not a 40"
        Thanks for your reply. I'm attaching the file i've read from the SPI flash chip with the fault (no display on screen), hope someone can see or compare it.
        I have tried re-flashing the same file back on the same chip and on another (new) chip, but fault remains. Also tried fitting a chip from a 50" Digihome tv and as expected worked but with some issues like inverted picture and un-steady picture (flickering).
          Looking for one for Samsung UE55F9000STXXU. Any leads?
            looking for, apex LE4643T, mainboard t.ms3391.a3b eeprom file
            thank you
              Hello forumers and cheers to all!
              I am hoping to find software for LG 42LF11UA TV North American market.
              I believe there's no problem with power board and or T-Con, the problem is either Mstar (IC100) chip or its corrupt software. I was able to de-solder FLASH chip and read it out/scan for bad blocks. If you could kick me in the right direction and/or throw some software for this model, I would be much appreciative of your generous contribution.
              Thanks.
                On a side note regarding this LG TV set, the main board appears to be dead and there's no indicator lights, however XTAL 12Mhz is alive and I was able to simulate backlight turn on, so inverter is also good. There's a short period of activity at power on (plug inserted into AC outlet) on BIOS EEPROM chip data lines, so maybe it needs re-flashing too. I could post dumps of those chips here for your review.
                Thanks.
                  Has anyone got the firmware for a LOGIK L32HED13A T.MSD309.B81C
                  Backlight working but nothing else remote sensor is working but no display
                    Thanks.
                    I hope someone could inspect those attached bin files and tell if they are valid.
                    Thanks.
                      Hello. I need you guys, to help me. I'm looking EEPROM dump for Samsung model: LE32R87BD. Model code: LE32R87BDX/XEU.
                      Mainboard: BN41-00813B-MP1.0 Panel: LTA320WT-L07
                      Thank you in advance.
                        Samsung UA46F7500 software file need
                          I guess there is no hope here...
                            Is there a tutorial on dumping/flashing eeprom chips and the software/hardware needed?
                              Supplied by DannyX
                                Software Screen TV SONY KLV- 32S550A 1-878-659-11
                                Submitted by Hosin0
                                  Software Screen ATA LE32D1
                                  Submitted by HosinO
                                    Originally posted by dick_barton View Post
                                    Supplied by DannyX
                                    https://www.badcaps.net/forum/showpo...&postcount=139
                                    TV details
                                      Samsung ua40f6400 software need
                                        Samsung ua32es5600r software need
                                          I need firmware for LG 26LD310
                                          Can someone please send me the link to download this firmware.
                                          Or I have this link but I am not able to register so can someone please download and send this to me.
                                          I will be very thank full to you.
                                          http://**************/dump/lcd_pdp_t.../246-1-0-34765
