bios for HP EliteBook x360 1030 G2
    Re: hp elitebook x360 1030 G2 BIOS!!
    Originally posted by 2taou.fik.58 View Post
    Hello, I've recently purchased a second-hand laptop.
    The previous owner did not tell me that the laptop has a BIOS password.
    After some research, I've successfully dumped the laptop's BIOS .bin file (16 MB).
    Here it is, could you please try and see if you can do anything to remove the password?
    Thank you very much.
    your bios is half empty .. read your bios again but remove the chip from the motherboard,after you have a verified and correct copy of the bios, you can write the chip with the bios from item # 2 and 4.
    try this one too..
      Logic error? Can't read again if it is overwritten with another dump.
      First try to get a correct dump, then start trying other files.
        Agreed. Get a good dump BEFORE trying to write anything. Otherwise you will brick the machine.
          you are right..I was not careful...well you have seen ..
          I modified it because I thought I would not read the following posts ...
            Please i need to unlock bios of an x360 1030 g2
            hi
            i need help to unlock the bios of an hp elite book x360 1030 g2
            i m in trouble cause i flash a bios from another computer and now the computer keep blinking.
            this is the orginal dump attached it need to be cleared.
            please help.
              Re: Please i need to unlock bios of an x360 1030 g2
              Try and give feedback
                think you you are genious can you give me the methode
                  i'm not but thank you , methode = you will find it here in this forum ...chahia tayba
                    thanks
                      Re: HP EliteBook x360 1030 G2 dump urgent
                      I there
                      I have one HP EliteBook x360 1030 G2 that the screen does not have backlight. The pc boots normaly but when i changed the screen, because the old one cracked, the screen backlight stopped working.
                      I have the chance to buy a used motherboard with bios locked supposedly working properly, can i copy the dump of the Bios of the old working and program the locked Bios with that dump? Since it has 2 ic chips, which one should i copy?
                      Appreciate the help in this subject.
                      Compliments
                        Re: UNLOCK BIOS PASSWORD HP EliteBook x360 1030 G2
                        Hi need to clear password
                          The bios posted here is not by Elitebook, it is by Spectre Pro x360 G2.
                          try bid 08197
                          https://www.badcaps.net/forum/showth...545#post966545
                            Your password seems to be fat2q
                              Hello !
                              I have an HP Elibook x360 1030 G2 which is blocked at the bios level.
                              I wanted to dump the blocked bios but neither Universal BIOS Backup ToolKit 2.0 nor De-CMOS3 works.
                              Do you have other programs to dump the bios?
                              Thank you !
                                You need an external programmer. You won't be able to flash back the stuff that needs to be modified otherwise.
                                  Re: HP EliteBook x360 1030 G2...help
                                  Can you remove the password please
                                  https://yadi.sk/d/uJjFzyTs2eDecg
                                    try..
                                      thank you so much. worked. We would appreciate it if you explain how to remove password.
                                        https://www.badcaps.net/forum/showthread.php?t=79956
                                          HP Elitebook x360 1030 G2
                                          I there
                                          I have a problem with the motherboard of this notebook.
                                          When i connect the power supply the power supply LED blinks 7 times, i was researching for this problem and found that this is a BIOS related problem.
                                          Then i flashed the Bios with a CH341 programmer and soldering tho the motherboard and still the same problem.
                                          Does anyone had similar problem or possible solution?
                                          note: I flashed the 128Mb bios, could the problem be on the other bios chip?
                                          Compliments
